Hi
I have installed Aeon skin on my Zotac box that runs openElec. I did this in System>Appearance>Skin>Get More, there was only one Aeon.
The problem is that it looks nothing like the video I have seen on it?
The first meny looks fine but visit for example Videos I just got a text list of my movies(filenames). If I select one I will get a image on the right side nothing more?
Have I wrong version or should it not be setup correcly by default?
Is there any better skin for the Zotac and OpenElec?
snowjim Wrote:Hi
You must set it how you like it. There are several different kinds of views available from which you can chose.
Press LEFT once or twice and you'll get a menu where you can chose 'view'
Put that on hdd or a stick and install (addons/install zip)
http://mod-skin.googlecode.com/files/xbm...-1.0.0.zip
After that restart maybe you dont have to do that.
Check for skins again you should see Aeon MQ3 now install, set the skin and then you get a wizard for easy configuration.
Martijn Wrote:You must set it how you like it. There are several different kinds of views available from which you can chose.
Thanks, I found that after a couple of tries.
TeKo Wrote:Put that on hdd or a stick and install (addons/install zip)
Thanks, Is Aeon MQ3 the more advanced skin? Will it work fine on a Zotac ND22?
I installed the Aeon under Get More Skins but there is no info on what flawor this is in(MQ3/NOX and so on)? I diid however notice that this version of Aeon was not as fast ad the default Confluence skin?
I use it on a crappy Netbook.
But you can set it to Lite for slower machines.
