2011-12-17, 18:01
Hello,
I activated live tv before I installed a add on for the client, now I get
the message that I have to active a add on before I use live tv and
if I try to deactivate the live tv xbmc crashes.
How can I disable the live tv?
Can I disable it in the console?
Is there a config / settings file?
Hope you can help me.
Greetings
I found it guisettings
<pvrmanager>
<channelmanager></channelmanager>
<channelscan></channelscan>
<enabled>false</enabled>
<resetdb></resetdb>
</pvrmanager>
but then I can not install a add on pvr client
Greetings
<pvrmanager>
<resetdb></resetdb>
</pvrmanager>
