I got a new bug? with the lastest svn version.
I get the same fanart for every sub-section..... it's quite hard to explain.
ie: you enter videos, then simpsons folder.... there's a fanart.jpg here....next you go to youtube, checking for new videos, the simpsons fanart is displayed in the background of youtube videos.... it shouldn't be there
I deleted my entire user\appdata\xbmc\user data\database\thumbnails\video\fanart\*.*
it didn't work and I'm kinda clueless.
Maybe it's not a transparency bug but an xbmc bug...
thanks.
ronie Wrote:there was a bug in xbmc that was causing this.
it should be fixed now:
https://github.com/xbmc/xbmc/commit/9216...3692aad934
Hi ronie,
I have this happening for me too, but I've updated to the latest nightly (10/12/11) but it's still there.
I relaise this isn't a transparency issue, but wondered if you knew if there was anything else I need to do - I've tried cleaning the database but that didn't do anything.
I've got this picture of Tom Cruise everywhere!!!
Buff Wrote:Hi ronie,
It won't be fixes until the beta-1 release
Cheers Martijn, good to know I'm not doing something wrong - just got to put up with that picture of Cruise for a while then!!
temp work around would be to seach your userdata/Thumbnails directory for a file named ffffffff.tbn
if you find it, delete it.
next, create an empty file with the same name and mark it read-only.
I did create a 0kb ffffffff.tbn but then I had black screen as fanart in my addons.
I reverted back to december 3rd xbmc and it fixes the problem for now.
kevenz Wrote:I did create a 0kb ffffffff.tbn but then I had black screen as fanart in my addons.
heh, at least that's better than facing tom cruise all of the time ;-)
