2011-12-18, 11:32
I need your help.
I have been trying to compile XBMC from Pulse-Eight github with AirPlay function, for dans, without any success.
I compiled and install libshairport and configure Xbmc with the following command line.
Sudo ./configure --enable-airplay --enable-airtunes
Everything seems to work fine, because I can read at the end of compilation process, AirPlay enable : yes and the same for AirTunes.
Following make and make install work fine, but when I run Xbmc and enable it to recieve AirPlay content, nothing.... My IPad doesn't see it...
I have then got several questions :
- what is the difference between AirPlay and AirTunes options ?
- what are the right options to write in ./configure command Line ?
- how I can verify if everything is correctly installed and configured ?
As you may have guess I am a fresh new linux user, and I really do need help..
If someone has got a How-to, I am interesseted in it ...
Thanks for your help.
S.
S.
