2011-12-19, 01:28
Alright so I am having a hard time to get xbmc to fit nicely on this 50" Plasma I have here... I believe I was able to in the past not sure why I cant now. I recently uninstalled it and reinstalled xbmc and installed new Graphic Card drivers.
I have HD 6xxx series.
According to AMD Vision Control Center it says maximum reported resolution is 1920x1080 for the tv so I go to xbmc settings and set that.
There is a Black Border on top and bottom and left side is cut off. I tried to using GPU scaling in AMD Vision Control Center and I can not get it even on the screen without cutting off the left.
So my question is what is best way to sync up xbmc with my tvs resolution so it fills from corner to corner without cutting off anything?
Im pretty sure I have had this working before its just I reinstalled xbmc along with the New AMD 12.1 Vision Control Center drivers which in honesty I think that may be the problem now that I think of it.
