Full Version: Remote Controllers for XBMC
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
This remote looks very nice, any experiences? nMEDIAPC HTPCKB-100 Wireless Home Theater PC Keyboard With IR
not me,,
I was cruzeing around the net researching for remote options and came accross this http://www.home-electro.com/ira3.php#Compatibility does anyone have any experience with this device? My goal was to try to find away to use my current remote.
(2012-04-07, 15:47)scrolling Wrote: [ -> ]I was cruzeing around the net researching for remote options and came accross this http://www.home-electro.com/ira3.php#Compatibility does anyone have any experience with this device? My goal was to try to find away to use my current remote.
These might be useful sources of information for the IRA 3
http://eatenbysomelinux.wordpress.com/20...-and-lirc/
http://forum.xbmc.org/showthread.php?tid=43320
http://lifehacker.com/5527752/control-yo...using-lirc
read the second section "Get Your Hardware Together"
Hello , first time poster here so please excuse my ignorance. I am currently putting together my first HTPC and the board i want to use has an IR header on it its the Asrock A75M-HVS AMD A75 Socket FM1, i also own a Logitech Harmony 900 and would like to use this for this.
I believe this to be possible but I am a little unsure of how I will go about this.
Any help appreciated.[/u]
corban, all u need is a MCE USB IR Receiver...
That's right, Corban. I use a Harmony as well adn I got my receiver by shelling out a whole 20 bucks for an Ortek VRC-1100 that came with one. It works wonderfully. I havne;t even used the actual remote..
Fair enough , seems like a nice easy solution , thanks Smile
Great job assembling information here.
I've been reading about the lag with Harmony remotes when using any USB receiver. Does anyone have experience with any universal remote that didn't lag?
i see no lag whatsoever!
just tweak your harmony remote speeds!
(2012-04-25, 19:59)eskro Wrote: [ -> ]i see no lag whatsoever!
That's interesting. Most people seem to report that tweaking the settings helps, but the response time remains significantly slower than a MCE remote.
Which harmony do you use?
650, the cheaper 300 cant tweak speeds
What IR receiver do you use?
HP MCE that registers as a EHOME TRANSCEIVER under HID in device manager
Thanks. That's the exact setup I'm considering.
I'm hoping that I will be able to WAKE from S5 on my asrock a75m-itx with this setup!?
