Full Version: Remote Controllers for XBMC
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
thats a maybe yes and maybe no. lets us know!
I Just purchased a HP receiver also I hope it will turn on my PC with the K400 connected. I will let you guys know if it works. I hope it does!
right on, let us know!
It should work. My usb wireless keyboard is able to do this, even not connected to the cir header enabled port through a bios change. Your motherboard will do the same as it uses the same bios as mine.
Ok I got the HP dongle and...
I can still power on my PC with the keyboard but not with my Harmony 650. I really would like to power it on with the remote but that's ok, I still don't have to get up to power the PC!
Eskro what your setting for the 650? I'm getting the lag and also sometimes like a double key press. Time to tweek the 650!
my settings, well, just use Harmony Desktop software,
and tweaks the speed settings to your liking.
even use the trouble shoot steps to get rid of the double key press u experiencing..
also, use MCE KEYBOARD as device.
sorry I mean the speed settings.
Hi guys,
I have a few questions :
Is it possible to control a lenovo ideacenter q180 using harmony remotes or the Motorola NYXboard Hybrid ?
Is it necessary to add a receiver to the lenovo or something similar?
Is it possible to boot straight from the remote?
thanks
(2012-04-29, 03:27)Chuck King Wrote: [ -> ]sorry I mean the speed settings.
u need to take some time and learn the Harmony Desktop software!
@anthony74700:
i dont own the lenovo ideacenter q180,
but i dont see why you couldnt use the harmony remote with it.
just get a USB IR RECEIVER and walla!
(2012-04-29, 20:21)eskro Wrote: [ -> ]
@anthony74700:
Great thank you but I imagine booting from the remote is not possible..?
i dont own the lenovo ideacenter q180 but i'D have to say No, not possible.
(2012-04-30, 18:53)eskro Wrote: [ -> ]i dont own the lenovo ideacenter q180 but i'D have to say No, not possible.
Ok thanks a lot for your support you are the HTPC Bible Nod
(2012-04-30, 19:55)anthony74700 Wrote: [ -> ]
haha!!
HTPC BiBLE!
I Like it!! Rofl
(2012-04-29, 13:24)anthony74700 Wrote: [ -> ]Hi guys,
thanks
I've got a Q180 and my USB IR receiver has just arrived from ebay today. I've got an old Harmony 525 so I'll let you know how I get on over the weekend.
(2012-05-11, 12:05)willp2003 Wrote: [ -> ]
thanks
great thanks
