Full Version: Problems with 4.04
Hi Ronie,
I'm on XBMC Pre Eden and downloaded from Add-On your new skin 4.04.
Now i have the Problem, if i click in the home menu the music button, in the
left down corner i have the following:
$VAR[ViewFanartLabel 7]
Music Add-Ons
$VAR[ViewFanartLabel 8]
$VAR[ViewFanartLabel 9]
Also if I click Settings in the Home Menu:
in Settings p.e. General there is : $VAR[SkinSettingsHeader]
Maybe you can help - thanks a lot
Excuse the bad English
Mike
most likely you're running a very old pre-eden build.
upgading to the latest one should fix your problem.
Hi Ronie
thanks for your answer. I'm on a special build with the new AudioEngine,
which is not updated in last time. I need that version to play HD Audio,is
there a opinion to change something, cause that problem is only in Audio screen, in Setting Screen i don't care about.
Maybe you can help.
Thanks a lot
Mike
you can checkout an earlier revision of T! svn.
if you switch back to r1181, you should be good go.
Thanks Ronie,
i downloaded und tried and it is fine now.
Merry christmas to you and your family
Mike
