Full Version: [RELEASE] NPR addon 2.0.0
Hey all,
I am happy to announce the next version of the NPR addon. This plugin now has support for every NPR station within the NPR database. I have done some minimal testing against Eden and it seems to work well. I would love to see some other XBMC folks try it out. If you are feeling up to it you may find the code at:
https://github.com/stieg/xbmc_npr
Simply drop the plugin directory into the local xbmc addon directory (~/.xbmc/addons/ on Linux) and restart XBMC. Enjoy.
Great addon works perfectly on Windows 7 64 bit Eden beta. Will keep you posted if any issues or any feature requests.
Thx
hunkyn Wrote:Great addon works perfectly on Windows 7 64 bit Eden beta. Will keep you posted if any issues or any feature requests.
Thx
Awesome. Thanks for giving it a test run.
Hello, it seems the link to the New York wfuv alternate side stream no longer works. I haven't been able to play it lately but the other 2 streams on that station work.
(2015-06-27, 17:18)jimbo2008 Wrote: [ -> ]Hello, it seems the link to the New York wfuv alternate side stream no longer works. I haven't been able to play it lately but the other 2 streams on that station work.
Howdy. Sorry for the delay as I was far far away from my computer for some time. Sorry to hear about WFUV not working. I probably need to rebuild the radio station index that the program uses. I'll re-post here when I get some time to do it. Haven't played with this plugin in some time.
