2011-12-25, 19:49
2011-12-25, 20:12
Are you referring to the weather in Dharma because I don't believe you can get this to work any more your need to install Eden Beta 1
2011-12-25, 23:28
i have eden beta 1. But the weather is not shown in the weatherscreen.
2011-12-25, 23:37
Lambada Wrote:i have eden beta 1. But the weather is not shown in the weatherscreen.
Run the location selecter in xbmc settings
2011-12-26, 00:10
As Martijn said have you added your location ?
If you have entered your location and its still not working your have to install the "Weather Underground" addon again but first your have to manually delete it from \XBMC\addons because you wont be able to uninstall it from addons once you have done that you can go back to addons and download it again
