Full Version: Exclude RAW (.CR2) files from Pictures?
Hi
I regularly use my XBMC setup to display pictures on our tv. Problem is, I keep both RAW and JPG files in the same folders (organised like this for years using Lightroom, so no way to change this). I would like to have XBMC skip the RAW files though, since these take quite a long time to load and almost 99% of the time do not display correctly anyway.
Is there a way to do this?
Yes advanced settings picture extensions
Found it, apparently had the extensions in upper case while lower case is required. Thx for the reply though.
