I updated to eden and now when i go to the main drive where my videos are it starts to load it and then says xbmc/boxee exited with status 11
i can get into boxee just fine. I tried to reinstall dharma but i cant download it. It doesnt start to download and just gives an error. Any help on this would be appreciated as this is my first time trying to do something with this. BOXEE PLAYS JUST FINE.
Um how do i access that i bought this off someone. So i never got a log in or anything.
by default (which is what most people leave it as) the SSH username and password should both be "frontrow"
Hi. I'm having the same problem with XBMC Eden (and also the latest Nightly build) on ATV 1. Mine reports that "xbmc/boxee exited with status: 6" (instead of 11).
My xbmc.log:
http://pastebin.com/Qqu20J5P
Thanks for any help on this issue.
Edit: I have aTV Flash installed. Dharma works without issues. Earlier nightly builds (pre-December, I think) used to work good also.
herrflick Wrote:Hi. I'm having the same problem with XBMC Eden (and also the latest Nightly build) on ATV 1. Mine reports that "xbmc/boxee exited with status: 6" (instead of 11).
My xbmc.log: http://pastebin.com/Qqu20J5P
ERROR: SQL: The database disk image is malformed
Thanks, davilla. Eden is working now.
I deleted the XBMC addons.db and addons15.db files from Apple Tv.
Thats the whole crash report log. The log is a gig in size. Ill try clearing it and see if it adds what you need
ANTHONYVANPYRE Wrote:http://pastebin.com/m18SyFfQ CRASH REPORT NEW
XFILE::CFileRar::Read
you have a bad rar file, xbmc.log might show which one.
