Full Version: XBMC On atv2 - Loc Settings fail
Hi guys,
Been searching my hair grey for answer to my problem.
my problem:
I'm using windows pc.
used putty to install xbmc onto my jailbroken Apple TV.
worked fine, got the latest version for eden build.
after the above, "all hell breaks loose" - When i want to add videos from my PC, through my home network wireless, i can find my pc allright, but when i want to connect to my pc inside XBMC, it gives me a screen "LOCK SETTINGS" where i put my username, pass etc.
What is this ? been trying to type my pc username//pass no luck, been trying all kind of combos with username//pass. ??
further to above i have read like most ppl who get this is because they have "Windows Live - sign in assistant" installed. - which I DONT have.
any way to work arround this ??
In the begining when i jailbroke my atv2, and installed XBMC i was so proud, cuz normally this aint my ball game.. but now ... sigh !
Thanks for your time and appreciate the answers to come.
cheers
- Madsen2204:confused2:
Closing this question, found out myself with help from my friend google :-)
Just had to disable password and set permissions for the folder to be shared..
