Full Version: New User - Help on video shot on Nikon D5100
I shoot some home video on my Nikon D5100. These are h.264/MPEG-4 AVC in a .mov container.
I can play these fine in Wind Media Player, but in xmbc, the sound and picture are wildly out of sync. The pic is very juddery.
Is the format supported (it appears to be)? Any other suggestions?
Thanks in advance for help
not sure but interlaced video may not be hardware accelerated so may judder?
Posting the mediainfo on pastebin then linking back will help diagnose... possibly and posting a debug log on pastebin is a good course of action.
Ps: welcome to the forums!
The format is supported. You could start by telling us anything about your setup. What OS are you on? What version of XBMC? What are the specs of your computer?
Sorry, Im fairly new to this... thanks for quick responses.
Its a WIN7 machine and I have the latest stable xmbc version (downloaded last week)
Im at work at mo and not entirely sure of exact machine spec. A friend of mine built it for me. I was using Win Media Centre but hated it. XBMC is brilliant so far, I have all my music, TV shows and films in the library Smile
Its just these home movies, the files do struggle to play on an old laptop (prob not powerful enough?) but they play fine in WMP on the same HTPC that I have xmbc installed.
If you need more info to help, tell me exactly what you need and Ill post it when I can.
Thanks again
Please can anyone help?
Get the mediainfo of the file
(see my sig)
and provided a debug log
http://wiki.xbmc.org/?title=Log_file
pseudo7 Wrote:and provide a debug log
Enable debug logging from System settings, System, Debugging, then close XBMC and start it again. Wait a minute or two for all the startup tasks to finish. Play a sample video, wait for it to start juddering then stop it and close XBMC.
Open the debug log by pressing Windows-R and in the Run dialog type:
"%appdata%\xbmc\xbmc.log"
(including the quotes). Click OK and the log should open in Notepad. Copy and paste the log into http://pastebin.com/ and post the link it gives you here.
JR
Here is the log on pastebin, all help appreciated
http://pastebin.com/ggnXhHAk
media file info
General
Complete name : D:\MCE Content\Videos\Home video\2011 Heather & Kathryn Dance1.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 229 MiB
Duration : 2mn 48s
Overall bit rate : 11.4 Mbps
Encoded date : UTC 2011-12-25 23:53:59
Tagged date : UTC 2011-12-25 23:53:59
NCDT : NCTG
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=12
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2mn 48s
Bit rate mode : Variable
Bit rate : 9 868 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.190
Stream size : 198 MiB (86%)
Language : English
Transfer characteristics : BT.470-6 System M, NTSC, FTC 73.682, BT.1700 625 PAL, BT.1700 625 SECAM
Matrix coefficients : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM, IEC 61966-2-4 601
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Duration : 2mn 48s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 30.8 MiB (13%)
Language : English
I'd guess it was a problem with the audio. It's not unknown for audio problems to cause video judder as well. XBMC is seeing the audio as:
INFO: ffmpeg[F48]: Stream #0.1(eng): Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
The video looks like standard h264. I'm afriad I don't know the audio code well enough to comment further.
JR
Thanks. The audio actually plays ok it's just the video that judders and lags the sound.
Is there anyone able to help further? All media info and debug log on page 1 of thread.
