Full Version: Phillips LCD and HP MCE Remote Control
ok.. so have a Phillips 40" LCD, the 5000 series model, but when I use my HP MCE Remote with my computer it causes the tv to reset and turn off/on. Really annoying, just wondering if anyone else has this issue? or has any recommendations to try?
HTPC Specs:
AMD x64 3000+
2GB Ram
Sata storage drive
Sata DVD-RW
IDE Main
HP MCE Remote + Receiver
Windows 7 Ultimate
Geforce FX5600 with DVI-HDMI adapter
Nforce3 Ultra Main Board
Have you updated to the latest TV firmware? Fixed all the issues I had with my 37" 5000 series. Download from Philips website, copy to USB stick, put in TV USB socket, really easy to do. First thing Philips will recommend.
http://www.p4c.philips.com/cgi-bin/dcbin...en&scy=GB# find your model from there
it came with the latest firmware
