2011-12-29, 12:50
Hi
Just wondering if there is a way I can partition my existing harddrive in my Acer Revo 3600 XbmcLive install.
When I did the original installation I just followed through the set up and let it partition the whole drive for XBMC.
Since then I have been using the video folder for movies.
With the upcoming release of Eden I would like to (if possible) create a new partition containing that video folder, and then leave a separate partition for the new XBMC install.
Is this possible (through terminal)?
How can I do it?
How big a partition should I use/leave for XBMC?
This is my existing fdisk -l
and this is my parted /dev/sda print
Thanks in advance.
Justin
How can I do it?
fdisk -l
Disk /dev/sda: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00088825
Device Boot Start End Blocks Id System
/dev/sda1 * 1 38351 308048896 83 Linux
/dev/sda2 38351 38914 4519937 5 Extended
/dev/sda5 38351 38914 4519936 82 Linux swap / Solaris
root@XBMCLive:~#
root@XBMCLive:~#
Model: ATA Hitachi HTS54503 (scsi)
Disk /dev/sda: 320GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Number Start End Size Type File system Flags
1 1049kB 315GB 315GB primary ext4 boot
2 315GB 320GB 4628MB extended
5 315GB 320GB 4628MB logical linux-swap(v1)
root@XBMCLive:~#
Justin
