Full Version: [Live] Xbox 360 controller always in focus on xbmc
I've been having an issue with launching emulators from XBMC.
The emulator will launch and load the rom fine. I can play it fine if I'm using the keyboard. However, if I try to play using the Xbox 360 controller, it is still focused on the XBMC interface and simply navigates that behind the open emulator.
I have tried launching using the Launcher plugin and the Advanced Launcher plugin.
Any help or suggestions would be greatly appreciated Smile
eskimogeorge Wrote:I've been having an issue with launching emulators from XBMC.
Controling XBMC using XBOX 360 controller does not mean that you will also automatically control the emulators. Do you have setup your XBOX 360 controller for each emulator? For example, if you start your emulators alone, could you control them using your XBOX 360 controller?
If you can control them... but not when using XBMC, that mean that XBMC keep the focus on all the XBOX 360 controller actions even when emulators are started. In this case, what you can do, is to suspend XBMC (http://www.gwenael.org/forum/viewtopic.php?id=5) or drastically close it (http://www.gwenael.org/forum/viewtopic.php?id=6) when emulators are running.
Angelscry Wrote:If you can control them... but not when using XBMC, that mean that XBMC keep the focus on all the XBOX 360 controller actions even when emulators are started. In this case, what you can do, is to suspend XBMC (http://www.gwenael.org/forum/viewtopic.php?id=5) or drastically close it (http://www.gwenael.org/forum/viewtopic.php?id=6) when emulators are running.
Thank you, suspending XBMC has solved my issue!
