Full Version: Apple TV 2G Problem to play Video-Files from my MBP
I have a Problem to play Videos in XBMC Version 11 beta!
I have connect the ATV2 and my Mac Book Pro via AFP... When I starting a Video, after 1-20min the bottom right while running the video "working" - then it stops and I´m still in the Main Menu of the ATV! I have Jailbreak my ATV 7 days before with Seasonpass and the untethered 4.3 and having the same Problem! Yesterday I have Jailbreak again with Seasonpass and the new 4.4.4 untethered.... Every day I have search for a solution in the Web. I have install Nano and edited the file "etc/hosts" via SSH, updatebegone and other "possible solutions"....
I now have several people referred to this forum!
I NEED HELP!!!!!!!
Why XBMC go back to Main Menu while running videos?
MacBookPro is installed OSX Lion
AppleTV 2 is installed 4.4.4 untethered Jailbreak and XBMC V11 EDEN beta
Need logs (at least the xbmc.log/debug log and the crash reporter one): http://wiki.xbmc.org/index.php?title=XBM...c_FAQ#logs
Hi at all,
AppleTV2:
Darwin 11.0.0 Darwin Kernel Version 11.0.0: Tue Nov 1
AppleTV2,1_4.4.4_9A406a
XBMC 11.0-BETA1 Git:20111222-22ad8e4 (Compiled : Dec 24 2011)
this is the Log-File of XBMC
http://pastebin.com/ZrxEc5UG
this is the Syslog Part 1
http://pastebin.com/yQwXz8zK
this is the Syslog Part 2
http://pastebin.com/GJjpS3x0
this is the crash log
http://pastebin.com/MYZn7646
When XBMC crashed, it goes to Main Menu in ATV !
Not in Main Menu XBMC... ATV Flash is not installed!
Thank you for your helpful answer @albertmartel
Is this the Problem
05:43:02 T:89116672 DEBUG: Error: Requested setting (videoscreen.screenmode) was not found. It must be case-sensitive
05:43:02 T:89116672 NOTICE: Checking resolution 12
05:43:02 T:89116672 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
In the future can you please use a site like pastebin to post log files?
Is this no Link to Pastebin?
I need help no answers like the last One! Look at the Link upside!
afp crash
ERROR: LIBAFPCLIENT: I have no idea what this is a reply to, id 2089.
not much we can do about it right now.
Can you elaborate? Once again on i-tunes to restore and re-jailbreak?
If there is currently no solution for this problem? LIBAFPCLIENT is indeed not a new topic in this forum ... However, not behind it with exactly this message! ERROR LIBAFPCLIENT is so unexplored topic? I have the ATV2 now for about three weeks and try it for about 1 1 / 2 weeks to get properly with XBMC! 'm Really desperate on, because I would really like to have been using XBMC ...
Because nobody knows any advice?
