Hi Guys
I have looked all over for the info I need but with no luck.
When I try to install through NitoTV or ssh I get the below errors
failed in buffer_write(fd) (7, ret=-1): backend dpkg-deb during `./Applications/XBMC.frappliance/XBMC': No space left on device
dpkg-deb: subprocess paste killed by signal (Broken pipe: 13)
Errors were encountered while processing:
/var/cache/apt/archives/org.xbmc.xbmc-atv2_11.0-0~b1_iphoneos-arm.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
Any help would be fab
No space arrrggghhhh
Cheers
D2
Guys
Iam slowly sorting this but how do I clear the cache
Apple-TV:~ root# df -k
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/disk0s1s1 630056 560312 63448 90% /
devfs 26 26 0 100% /dev
/dev/disk0s1s2 7152344 289856 6862488 5% /private/var
Apple-TV:~ root# du -h
360K ./Library/Caches/locationd
8.0K ./Library/Lockdown/activation_records
8.0K ./Library/Lockdown/escrow_records
8.0K ./Library/Lockdown/pair_records
48K ./Library/Lockdown
0 ./Library/Logs/awd
0 ./Library/Logs
16K ./Library/Preferences
424K ./Library
0 ./Media/Cydia/AutoInstall
0 ./Media/Cydia
0 ./Media
432K .
check on youtube. there is a video i follow on there that help me install nito.
WARNING: The following packages cannot be authenticated!
org.xbmc.xbmc-atv2
Install these packages without verification [y/N]? y
(Reading database ... 2593 files and directories currently installed.)
Unpacking org.xbmc.xbmc-atv2 (from .../org.xbmc.xbmc-atv2_11.0-0~b1_iphoneos-arm.deb) ...
dpkg: error processing /var/cache/apt/archives/org.xbmc.xbmc-atv2_11.0-0~b1_iphoneos-arm.deb (--unpack):
failed in buffer_write(fd) (7, ret=-1): backend dpkg-deb during `./Applications/XBMC.frappliance/Frameworks/libsmbclient.dylib.0': No space left on device
Apple-TV:/var/cache/apt/archives root# Write failed: Broken pipe
MacBook-Pro-de-Wesley:~ wesley76$ ssh
[email protected]
[email protected]'s password:
/dev/disk0s1s1 630056 600544 23216 97% /
/dev/disk0s1s2 7152344 275728 6876616 4% /private/var
Apple-TV:~ root#
hi can anyone help please i have installed hulu, when i try and click on the movie i want
i get a window box asking me to select resolution but the box is Empty
