Full Version: Logitech F310
Hello
I recently purchased a Logitech F310 gampad and thought of using advanced launcher will be perfect for gaming, but have tried everything but the XBMC 11 (b1) does not support the gamepad (Xinput, Direct input, xpadder key id -> gamepad-keyboard.xml etc., does not work).
What you need to set it? Thank you for your response.
ConfusedHuh The game pad does not need to work in XBMC. You launch the emulator from within XBMC using advanced launcher and your remote. Then when the emulator takes control you use the game pad. Just make sure you get the game pad working inside the emulators and you should be fine.
htpc guy Wrote:ConfusedHuh The game pad does not need to work in XBMC. You launch the emulator from within XBMC using advanced launcher and your remote. Then when the emulator takes control you use the game pad. Just make sure you get the game pad working inside the emulators and you should be fine.
Absolutely not work anywhere in the XBMC.
(Sorry, google translate Smile )
