Full Version: Mediaportal TV Server+For the Record Backend
Hi.
I am using XBMC PVR with Mediaportal and For the Record backend. I am not using Argus. I am using the Mediaportal TV server. How can I make this work properly with XBMC? The 4TR addon does not seem to work if you arent using Argus. The Mediaportal addon works but schedules recordings using Mediaportal and not 4TR leaving things a bit fragmented. Is there a solution or workaround at this time?
Much thanks.
Not supported and not likely to be added soon as an option.
K. Thanks. And thanks for your continued development of the plugin(s). Phenomenal.
