Full Version: xbmc pvr + media portal tv server - unwachable content
im trying to find answer for my problem. I installed XBMC with pvr support xbmc-11.0-Eden_beta1_pvr-margro and also tryed xbmc-10.1-PVR_v2 with mediaportal tv server 1.2.2
everything works (except EPG as know bug, as i read somewhere here in forum) but i cant play live tv therefore i can play it but the picture is unwachable, sound is crappy, noisy. in other words i cant recognize what is on the picture.
I tryed installation on two different computer but the result is the same. The second installation was on clear system windows 7 64bit
Here is my log. I remove old .log file and run xbmc interface and just run live tv.
here is link to my log
glooom Wrote:Hi,
Have you tried LiveTV with Mediaportal Client ? Does it work ? It didn't for me .. so it's may be again only a Mediaportal problem .. with windows better try DVBViewer or WMC7 ...
So long
LastCoder
Is your client wireless?
I'm currently using the early december (12/4 or 12/5) Win7 build and it does work. I haven't tried any newer build (Eden beta) yet. I have a wireless-g client (OpenELEC) and sometimes HD channels get macroblocked pretty bad, but i'm pretty sure it's a bandwidth thing.
i dont want to use wmc7 any more. all features in wmc must be installed with third party application. i also have dvblink streamed to wmc.
all of this is not so quick as xbmc. xbmc is nice app, but it must have pvr fuction for me.
Kirky99 Wrote:Is your client wireless?
no, XBMC and mediaportal tv server are installed on the same computer
is there any solution?
glooom Wrote:is there any solution?
did you test mediaportal *client* for watching TV .. if that doesn't work then there is no need for finding solutions for (mostly unstable) PVR XBMC support ...
