All of a sudden I am getting a script error message for service.py........
I can't figure out where it is coming from. Can anyone tell me how to get rid of it?
Thank You
I am assuming this is a result of runnning an addon...going to need mroe info though ie..what were you trying to run and a full and proper debug log.
The message comes up when I open XBMC, not when I am trying to run an add-on
Powerspot Wrote:The message comes up when I open XBMC, not when I am trying to run an add-on
Add-on are also run at startup.
Post a full
Debug Log using pastebin.com
Showing my inexperience here.....lol.....how do i get to or make a debug log?
you need to turn on debug logging I believe it is under settings somewhere, I will have to check. Get the machine to re-create the issue, then all you need to do is pull down the log file then head over to pastebin.
Its under settings and systems. Also what system are you running sometimes the output file goes to another place when dealing with windows, linux or the ATV
It was the TV Guide plugin causing the issue.
Thank you for the help
