2012-01-03, 00:55
I've been using XBMC on an ATV2 from its first release, including most of the nightlies until the Eden beta. I've noticed what seems to be a new behavior when scraping under Eden that I believe is a bug.
Usually if I've added a new TV episode or two, I go to that episode's title in the TV library and select "Scan for new content" instead of Update Library because it's much faster. This has always worked well until Eden. Now, it seems that XBMC is caching the contents differently, and it no longer "sees" new content unless I exit from the TV library completely or do the scan from file view. This is true even if I add an entire Season folder and not just a single new episode.
"Update library" works fine, but because I have a large library, that takes quite a bit longer.
Anyone else seeing this?
