Add-on to play some of news channel @ rentadrone.tv,
Currently it plays
- MSNBC
- CNBC
- CNN
- CNN International
- BBC World News
- HLN
Update:
Created the repository and download it from
here
Nice work dude! Thanks alot! 5 star
This is a great plugin. It is nice to have MSNBC and CNN live! Thanks for the work. This is repo material!
This is a great plugin, I use it constantly. Well, "used" is more appropriate as this morning it stopped working for me.
09:26:19 T:2628 M:4294967295 NOTICE: -->Python Interpreter Initialized<--
09:26:19 T:2628 M:4294967295 ERROR: Error Type: exceptions.IndexError
09:26:19 T:2628 M:4294967295 ERROR: Error Contents: list index out of range
09:26:19 T:2628 M:4294967295 ERROR: Traceback (most recent call last):
File "C:\Users\XXXX\AppData\Roaming\XBMC\addons\plugin.video.rentadrone\default.py", line 123, in ?
STREAMS()
File "C:\Users\XXXX\AppData\Roaming\XBMC\addons\plugin.video.rentadrone\default.py", line 21, in STREAMS
match=re.compile('Home(.+?)About The Live News Rentadrone').findall(match[0])
IndexError: list index out of range
09:26:19 T:2400 M:4294967295 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.rentadrone/
09:26:19 T:2400 M:4294967295 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.rentadrone/) failed
09:26:19 T:148 M:4294967295 WARNING: XFILE::CFactoryDirectory::Create - Unsupported protocol(script) in script://
Anyone have any ideas? My apologies if this is not the correct location for this post.
Thanks for the default.py. Got it working again! Thanks for the quick fix!
The site layout was updated. I updated the add-on, you can installed thru repository.
kevlarsoul Wrote:This is a great plugin, I use it constantly. Well, "used" is more appropriate as this morning it stopped working for me.
STREAMS()
Layout was updated, install the
repo and it will update the addon.
bobpeace Wrote:Thanks for the default.py. Got it working again! Thanks for the quick fix!
Install the
I'm still getting the same message---script failed message
instead you should make the add-on self-updating with the instructions from the wiki. New repo zip for a single addon is overkill.
ztas Wrote:Install the repo and it will update the addon.
me123 Wrote:I'm still getting the same message---script failed message
try re-installing and if you still get error. post the error log
macf1an Wrote:instead you should make the add-on self-updating with the instructions from the wiki. New repo zip for a single addon is overkill.
Sure, i'll try that.
All working fine for me. (ATV2. Eden2) Thanks for updating Ztas. I use the plugin every day :-)
