2012-01-03, 16:49
I am running openelec(XBMC on Linux) generic on my Zotac HD-ND22 and it have been working okay. We was however watching a 1080p movie today and it was alot of lag in the picture every 30 min or so.
The movie was streamed over a 10/100 network so this should not be any problems.
I was forced to restart the move 4 times and the openelec restarted XBMC twice(probably crash). When playing the same part again it went just fine.
This is what MediaInfo got :
Any thoughts on why this clip created problems for XBMC on this hardware?
Quote:Unique ID : 179432663160537105529634469504253498848 (0x86FD795164822A6B99F9ED4FBC1D15E0)
Complete name : G:\Movie\Not seen\Rise.of.the.Planet.of.the.Apes...
Format : Matroska
Format version : Version 2
File size : 12.0 GiB
Duration : 1h 44mn
Overall bit rate : 16.3 Mbps
Encoded date : UTC 2011-11-19 14:20:32
Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 44mn
Bit rate : 14.8 Mbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.394
Stream size : 10.6 GiB (89%)
Title : Rise.of.the.Planet.of.the.Apes...
Writing library : x264 core 116 r2074 2641b9e
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=tesa / subme=11 / psy=1 / psy_rd=1.05:0.05 / mixed_ref=0 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=90 / rc=2pass / mbtree=1 / bitrate=14800 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=2:0.70
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 44mn
Bit rate mode : Constant
Bit rate : 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.11 GiB (9%)
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Language : Bulgarian
Default : No
Forced : No
Text #3
Format : UTF-8
Language : Greek
Default : No
Forced : No
Text #4
Format : UTF-8
Language : Romanian
Default : No
Forced : No
Text #5
Format : UTF-8
Language : Turkish
Default : No
Forced : No
Text #6
Format : UTF-8
Language : Italian
Default : No
Forced : No
Text #7
Format : UTF-8
Language : Portuguese
Default : No
Forced : No
Text #8
Format : UTF-8
Language : Danish
Default : No
Forced : No
Text #9
Format : UTF-8
Language : Swedish
Default : No
Forced : No
Text #10
Format : UTF-8
Language : Spanish
Default : No
Forced : No
Text #11
Format : UTF-8
Language : Chinese
Default : No
Forced : No
Text #12
Format : UTF-8
Language : French
Default : No
Forced : No
Text #13
Format : UTF-8
Language : Dutch
Default : No
Forced : No
