2005-05-02, 11:13
i just updated to the 5/2 cvs build. and well im having nothing but probs. here is my log file, from a full log session.
02-05-2005 04:54:40 notice -----------------------------------------------------------------------
02-05-2005 04:54:40 notice starting...
02-05-2005 04:54:40 notice q is mapped to:harddisk0\partition6\apps\xbmc
02-05-2005 04:54:40 notice load settings...
02-05-2005 04:54:40 notice loading t:\settings.xml
02-05-2005 04:54:40 notice getting hardware information now...
02-05-2005 04:54:40 notice checking resolution 10
02-05-2005 04:54:40 notice av pack: standard
02-05-2005 04:54:40 notice av flags:
02-05-2005 04:54:40 notice setting autoresolution mode 4
02-05-2005 04:54:40 notice loading q:\xboxmediacenter.xml
02-05-2005 04:54:40 info key combination detected for full debug logging (x+y)
02-05-2005 04:54:40 info map drives...
02-05-2005 04:54:40 info map drive c:
02-05-2005 04:54:40 info map drive e:
02-05-2005 04:54:40 info map drive d:
02-05-2005 04:54:40 info map drive f:
02-05-2005 04:54:40 info drives are mapped
02-05-2005 04:54:40 info checking skinpath existance, and existence of keymap.xml:q:\skin...
02-05-2005 04:54:40 debug setting resolution 4
02-05-2005 04:54:40 debug we set resolution 4
02-05-2005 04:54:41 debug we set resolution 4
02-05-2005 04:54:41 debug splash image q:\media\splash.png not found
02-05-2005 04:54:41 info load language file:q:\language\english\strings.xml
02-05-2005 04:54:41 notice loaded q:\system\players\mplayer\iso639-1.xml
02-05-2005 04:54:41 notice loaded q:\system\players\mplayer\iso639-2.xml
02-05-2005 04:54:41 info load keymapping
02-05-2005 04:54:41 info loading q:\keymap.xml
02-05-2005 04:54:41 info checking skin version of: project mayhem iii
02-05-2005 04:54:41 info skin version is: 1.3
02-05-2005 04:54:41 info gui format 720x480 ntsc 4:3
02-05-2005 04:54:41 info gui screen offset (0,0)
02-05-2005 04:54:41 info install unhandled exception filter
02-05-2005 04:54:41 info creating subdirectories
02-05-2005 04:54:41 info thumbnails folder:q:\thumbs
02-05-2005 04:54:41 info shortcuts folder:q:\shortcuts
02-05-2005 04:54:41 info albums folder:q:\albums
02-05-2005 04:54:41 info recording folder:q:\recordings
02-05-2005 04:54:41 info screenshots folder:q:\screenshots
02-05-2005 04:54:41 info subtitle folder:q:\subtitles
02-05-2005 04:54:41 notice initialize assignment:[dhcp] network ip:[192.168.0.3] netmask:[255.255.255.0] gateway:[192.168.0.1] nameserver:[0.0.0.0]
02-05-2005 04:54:41 notice use dhcp
02-05-2005 04:54:41 info setting up network...
02-05-2005 04:54:41 info requesting dhcp
02-05-2005 04:54:43 info full duplex
02-05-2005 04:54:43 info 100 mbps
02-05-2005 04:54:43 info dynamic ip
02-05-2005 04:54:43 info dns
02-05-2005 04:54:43 info ip: 192.168.1.101
02-05-2005 04:54:43 info get local ip address:
02-05-2005 04:54:43 info ip adres:192.168.1.101
02-05-2005 04:54:43 notice start timeserver thread
02-05-2005 04:54:43 notice start ftpserver
02-05-2005 04:54:43 notice start led control
02-05-2005 04:54:43 notice dim lcd on playback
02-05-2005 04:54:43 notice start dvd mediatype detection
02-05-2005 04:54:43 notice initializing playlistplayer
02-05-2005 04:54:43 info lcd not used
02-05-2005 04:54:43 notice start fancontroller
02-05-2005 04:54:43 notice load default skin:[project mayhem iii]
02-05-2005 04:54:43 info load skin from:q:\skin\project mayhem iii
02-05-2005 04:54:43 info delete old skin...
02-05-2005 04:54:43 info default 4:3 resolution directory is q:\skin\project mayhem iii\pal
02-05-2005 04:54:43 info default 16:9 resolution directory is q:\skin\project mayhem iii\pal16x9
02-05-2005 04:54:43 info skin version is: 1.3
02-05-2005 04:54:43 info load fonts for skin...
02-05-2005 04:54:43 info loading fonts from q:\skin\project mayhem iii\ntsc\font.xml
02-05-2005 04:54:43 info load font:font18 path:q:\skin\project mayhem iii\fonts\common-font18.xpr
02-05-2005 04:54:43 info load font:font13 path:q:\skin\project mayhem iii\fonts\common-font13.xpr
02-05-2005 04:54:43 info load font:font14 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
02-05-2005 04:54:43 info load font:font64 path:q:\skin\project mayhem iii\fonts\common-font64.xpr
02-05-2005 04:54:43 info load font:matrix8 path:q:\skin\project mayhem iii\fonts\matrix8.xpr
02-05-2005 04:54:43 info load font:font04 path:q:\skin\project mayhem iii\fonts\common-font14.xpr
02-05-2005 04:54:43 info load font:font12 path:q:\skin\project mayhem iii\fonts\common-font12.xpr
02-05-2005 04:54:43 info load font:font10 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
02-05-2005 04:54:43 info load font:font15 path:q:\skin\project mayhem iii\fonts\common-font15.xpr
02-05-2005 04:54:43 info load font:fontkb path:q:\skin\project mayhem iii\fonts\common-font13.xpr
02-05-2005 04:54:43 info load font:font101 path:q:\skin\project mayhem iii\fonts\common-font10.xpr
02-05-2005 04:54:43 info load fontpecial12 path:q:\skin\project mayhem iii\fonts\special-normal.xpr
02-05-2005 04:54:43 info load fontpecial13 path:q:\skin\project mayhem iii\fonts\special-bold.xpr
02-05-2005 04:54:43 info load new skin...
02-05-2005 04:54:44 info skin version is: 1.3
02-05-2005 04:54:44 info loading skin file: home.xml
02-05-2005 04:54:44 info loading references file: q:\skin\project mayhem iii\ntsc\references.xml
02-05-2005 04:54:44 info loading skin file: myprograms.xml
02-05-2005 04:54:44 info loading skin file: mypics.xml
02-05-2005 04:54:44 info loading skin file: filemanager.xml
02-05-2005 04:54:44 info loading skin file: myvideo.xml
02-05-2005 04:54:44 info loading skin file: myvideogenre.xml
02-05-2005 04:54:44 info loading skin file: myvideoactors.xml
02-05-2005 04:54:44 info loading skin file: myvideoyear.xml
02-05-2005 04:54:44 info loading skin file: myvideotitle.xml
02-05-2005 04:54:44 info loading skin file: settings.xml
02-05-2005 04:54:44 info loading skin file: myvideoplaylist.xml
02-05-2005 04:54:44 info loading skin file: settingssysteminfo.xml
02-05-2005 04:54:44 info loading skin file: dialogalbuminfo.xml
02-05-2005 04:54:44 info loading skin file: dialogscriptinfo.xml
02-05-2005 04:54:44 info loading skin file: settingsprofile.xml
02-05-2005 04:54:44 info loading skin file: dialogyesno.xml
02-05-2005 04:54:44 info loading skin file: dialogprogress.xml
02-05-2005 04:54:44 info loading skin file: dialogvolumebar.xml
02-05-2005 04:54:44 info loading skin file: dialogkaitoast.xml
02-05-2005 04:54:44 info loading skin file: dialognumeric.xml
02-05-2005 04:54:44 info loading skin file: dialoggamepad.xml
02-05-2005 04:54:44 info loading skin file: dialogsubmenu.xml
02-05-2005 04:54:44 info loading skin file: dialogbuttonmenu.xml
02-05-2005 04:54:44 info loading skin file: dialogcontextmenu.xml
02-05-2005 04:54:44 info loading skin file: dialogmusicscan.xml
02-05-2005 04:54:44 info loading skin file: playercontrols.xml
02-05-2005 04:54:44 info loading skin file: mymusicplaylist.xml
02-05-2005 04:54:44 info loading skin file: mymusicsongs.xml
02-05-2005 04:54:44 info loading skin file: mymusicnav.xml
02-05-2005 04:54:44 info loading skin file: mymusictop100.xml
02-05-2005 04:54:44 info loading skin file: dialogselect.xml
02-05-2005 04:54:44 info loading skin file: dialogok.xml
02-05-2005 04:54:44 info loading skin file: dialogfilestacking.xml
02-05-2005 04:54:44 info loading skin file: dialogvideoinfo.xml
02-05-2005 04:54:44 info loading skin file: musicoverlay.xml
02-05-2005 04:54:44 info loading skin file: settingsuicalibration.xml
02-05-2005 04:54:44 info loading skin file: settingsscreencalibration.xml
02-05-2005 04:54:44 info loading skin file: settingscategory.xml
02-05-2005 04:54:44 info loading skin file: videooverlay.xml
02-05-2005 04:54:44 info loading skin file: videofullscreen.xml
02-05-2005 04:54:44 info loading skin file: myscripts.xml
02-05-2005 04:54:44 info loading skin file: musicvisualisation.xml
02-05-2005 04:54:44 info loading skin file: slideshow.xml
02-05-2005 04:54:44 info loading skin file: videoosd.xml
02-05-2005 04:54:45 info loading skin file: myweather.xml
02-05-2005 04:54:45 info loading skin file: dialoginvite.xml
02-05-2005 04:54:45 info loading skin file: dialoghost.xml
02-05-2005 04:54:45 info loading skin file: dialogkeyboard.xml
02-05-2005 04:54:45 info loading skin file: mybuddies.xml
02-05-2005 04:54:45 info loading skin file: pointer.xml
02-05-2005 04:54:45 info loading skin file: dialogmutebug.xml
02-05-2005 04:54:45 info loading user windows q:\skin\project mayhem iii\pal\custom*.xml
02-05-2005 04:54:45 info loading skin file: q:\skin\project mayhem iii\pal\custom1.xml
02-05-2005 04:54:45 info loading skin file: q:\skin\project mayhem iii\pal\custom3.xml
02-05-2005 04:54:45 info initialize new skin...
02-05-2005 04:54:45 info loading q:\skin\project mayhem iii\sounds\sounds.xml
02-05-2005 04:54:45 info skin loaded...
02-05-2005 04:54:45 info initializing skin
02-05-2005 04:54:45 info kaiclient: instantiating...
02-05-2005 04:54:45 debug udpclient: creating udp socket...
02-05-2005 04:54:45 debug udpclient: setting broadcast socket option...
02-05-2005 04:54:45 debug udpclient: setting non-blocking socket options...
02-05-2005 04:54:45 debug udpclient: spawning listener thread...
02-05-2005 04:54:45 debug udpclient: ready.
02-05-2005 04:54:45 info kaiclient: ready.
02-05-2005 04:54:45 notice kaiclient: discovering kai engine via udp broadcast.
02-05-2005 04:54:45 info activating window id: 10000
02-05-2005 04:54:45 info removing tempfiles
02-05-2005 04:54:45 info checking bookmarks for special directories
02-05-2005 04:54:45 notice initialize done
02-05-2005 04:54:45 notice running the application...
02-05-2005 04:54:45 info get url: http://www.xbox-scene.com/xbox1data/xbox-scene.xml
02-05-2005 04:54:47 debug udpclient: listening.
02-05-2005 04:54:47 debug udpclient tx: 7752 -> 'kai_client_discover;'
02-05-2005 04:54:53 debug freevisualisation() started
02-05-2005 04:54:53 debug freevisualisation() done
02-05-2005 04:54:53 info activating window id: 10004
02-05-2005 04:54:58 info activating window id: 10016
02-05-2005 04:55:31 debug freevisualisation() started
02-05-2005 04:55:31 debug freevisualisation() done
02-05-2005 04:55:31 info activating window id: 10006
02-05-2005 04:55:31 info attempting to default to:
02-05-2005 04:56:01 info mplayer playmb://vykland-6ef1wdu/anime/zeta gundam/[2xx]zeta gundam - 32(eng sub).ogm cachesize:12288
02-05-2005 04:56:01 debug initializing fs_seg..
02-05-2005 04:56:01 debug fs segment @ 0x8863c0
02-05-2005 04:56:02 info flipping bi-directional subtitles disabled
02-05-2005 04:56:02 debug msg:enable mplayer osd
02-05-2005 04:56:02 debug msg:mplayer dev-cvs-050410-13:35 © 2000-2004 mplayer team
02-05-2005 04:56:02 debug msg:cpu: intel celeron 2/pentium iii coppermine,geyserville
02-05-2005 04:56:02 debug msgfamily: 6, stepping: 10)
02-05-2005 04:56:02 debug msg:detected cache-line size is 32 bytes
02-05-2005 04:56:02 debug msg:cpuflags: mmx: 1 mmx2: 1 3dnow: 0 3dnow2: 0 sse: 0 sse2: 0
02-05-2005 04:56:02 debug msg:compiled for x86 cpu with extensions:
02-05-2005 04:56:02 debug msg: mmx
02-05-2005 04:56:02 debug msg: mmx2
02-05-2005 04:56:02 debug msg: sse
02-05-2005 04:56:02 debug msg:78 audio & 187 video codecs
02-05-2005 04:56:02 debug msg:mplayer_open_file(smb://vykland-6ef1wdu/anime/zeta gundam/[2xx]zeta gundam - 32(eng sub).ogm)
02-05-2005 04:56:02 info stating file smb://vykland-6ef1wdu/anime/zeta gundam/[2xx]zeta gundam - 32(eng sub).ogm.conf
02-05-2005 04:56:02 info stating file q:\system\players\mplayer\[2xx]zeta gundam - 32(eng sub).ogm.conf
02-05-2005 04:56:02 debug msg:playing smb://vykland-6ef1wdu/anime/zeta gundam/[2xx]zeta gundam - 32(eng sub).ogm.
02-05-2005 04:56:02 debug msg:auto open z:\subtitle
02-05-2005 04:56:02 debug msg:protocolmb
02-05-2005 04:56:02 debug msg:use standard file for protocolmb
cache fill: 0.00% (0 bytes)
cache fill: 1.04% (131072 bytes)
cache fill: 2.08% (262144 bytes)
cache fill: 3.13% (393216 bytes)
cache fill: 4.17% (524288 bytes)
cache fill: 5.21% (655360 bytes)
cache fill: 5.73% (720896 bytes)
cache fill: 6.77% (851968 bytes)
cache fill: 7.81% (983040 bytes)
cache fill: 8.85% (1114112 bytes)
cache fill: 10.42% (1310720 bytes)
cache fill: 11.46% (1441792 bytes)
cache fill: 12.50% (1572864 bytes)
cache fill: 13.02% (1638400 bytes)
cache fill: 14.06% (1769472 bytes)
cache fill: 15.10% (1900544 bytes)
cache fill: 15.63% (1966080 bytes)
cache fill: 16.67% (2097152 bytes)
cache fill: 17.71% (2228224 bytes)
cache fill: 18.75% (2359296 bytes)
cache fill: 19.79% (2490368 bytes)
02-05-2005 04:56:02 error cmplayer::openfile() smb://vykland-6ef1wdu/anime/zeta gundam/[2xx]zeta gundam - 32(eng sub).ogm failed
02-05-2005 04:56:14 info activating window id: 10000
02-05-2005 04:58:03 debug freevisualisation() started
02-05-2005 04:58:03 debug freevisualisation() done
02-05-2005 04:58:03 info activating window id: 10004
02-05-2005 04:58:05 info activating window id: 10016
02-05-2005 04:58:23 info activating window id: 10018
02-05-2005 04:58:27 info activating window id: 10014
02-05-2005 04:58:38 info get url: http://xoap.weather.com/search/search?where=12553
02-05-2005 04:58:44 info activating window id: 10017
02-05-2005 04:59:14 debug freevisualisation() started
02-05-2005 04:59:14 debug freevisualisation() done
02-05-2005 04:59:14 info activating window id: 10006
02-05-2005 04:59:21 error exception in capplication::framemove()
02-05-2005 04:59:21 fatal exception_access_violation (0xc0000005)
at 0x00c56dfc
that's just the latest one, ive also seen where i dont even get the framemove bit. just open file failed then the access violation. and its not just with .ogm files it has happened with all file formats. and it doesn't always happen, i could watch 6-7 files then the next one locks everything up. hopefully someone can steer me in the right direction. thanks
edit: this just happened when i tried going back to my dash
02-05-2005 05:11:46 notice -----------------------------------------------------------------------
02-05-2005 05:11:46 notice starting...
02-05-2005 05:11:46 notice q is mapped to:harddisk0\partition6\apps\xbmc
02-05-2005 05:11:46 notice load settings...
02-05-2005 05:11:46 notice loading t:\settings.xml
02-05-2005 05:11:46 notice getting hardware information now...
02-05-2005 05:11:46 notice checking resolution 10
02-05-2005 05:11:46 notice av pack: standard
02-05-2005 05:11:46 notice av flags:
02-05-2005 05:11:46 notice setting autoresolution mode 4
02-05-2005 05:11:46 notice loading q:\xboxmediacenter.xml
02-05-2005 05:11:47 notice loaded q:\system\players\mplayer\iso639-1.xml
02-05-2005 05:11:47 notice loaded q:\system\players\mplayer\iso639-2.xml
02-05-2005 05:11:47 notice initialize assignment:[dhcp] network ip:[192.168.0.3] netmask:[255.255.255.0] gateway:[192.168.0.1] nameserver:[0.0.0.0]
02-05-2005 05:11:47 notice use dhcp
02-05-2005 05:11:49 notice start timeserver thread
02-05-2005 05:11:49 notice start ftpserver
02-05-2005 05:11:49 notice start led control
02-05-2005 05:11:49 notice dim lcd on playback
02-05-2005 05:11:49 notice start dvd mediatype detection
02-05-2005 05:11:49 notice initializing playlistplayer
02-05-2005 05:11:49 notice start fancontroller
02-05-2005 05:11:49 notice load default skin:[project mayhem iii]
02-05-2005 05:11:51 notice kaiclient: discovering kai engine via udp broadcast.
02-05-2005 05:11:51 notice initialize done
02-05-2005 05:11:51 notice running the application...
02-05-2005 05:12:43 notice start led control
02-05-2005 05:12:43 notice dim lcd on playback
02-05-2005 05:13:43 notice start led control
02-05-2005 05:13:43 notice dim lcd on playback
02-05-2005 05:13:50 error cmplayer::openfile() smb://vykland-6ef1wdu/anime/zeta gundam/[2xx]zeta gundam - 31(eng sub).ogm failed
02-05-2005 05:14:03 notice stop all
02-05-2005 05:14:03 notice stop time server
02-05-2005 05:14:03 notice stop dvd detect media
02-05-2005 05:14:04 notice stop fancontroller
02-05-2005 05:14:04 notice stop mplayer
02-05-2005 05:14:04 notice stop python
02-05-2005 05:14:04 fatal exception_access_violation (0xc0000005)
at 0x01756dfc
at 0x00c56dfc
at 0x01756dfc
