Can You Improve XBMC with installing codecs or other programs ?
I am using the internal player in xbmc and it is not perfect and my windows is after format.
I dont have any program or codec, can i install samething to improve my internal xbmc player ?
Nope, XBMC does not use external codecs.
Ok so i just try all of your options
- VLC, TMT 5, MPC-HC, PowerDVD.
All the codecs thet you give me and the "Internal player" in XBMC worked A lot Better !!! (For Me) . still little bit choppy but better then all of them.
alexkam87 Wrote:Ok so i just try all of your options - VLC, TMT 5, MPC-HC, PowerDVD.
Nothing can playback more fluent than the standalone TMT5, PowerDVD11 and MPC-HC. You can set external to playback blu-ray disc and BD iso/m2ts/mkv to enjoy 1080P video with DTS-HD and TrueHD audio, and XBMC will playback the rest (Music, Photo, DVD, MP4, AVI, etc). You need to make sure your GPU driver is up to date!
Here are steps:
1. Download-
AnyDVD HD (you have 14 days free trail)
2. Download-
Virtual CloneDrive (it's free)
3. Download-
XBMC 11.0 "Eden" Beta 1
4. Download all the files below and change directories in it to match the directories in your HTPC:
a.
playercorefactory.xml
b.
PlayBDMV
c.
PlayDisc
d.
PlayISO
but then you get stuck using a different remote for each one.
robl45 Wrote:but then you get stuck using a different remote for each one.
Not really, I use the same MCE remote for everything. You can change keymap in MPC-HC option to your choice. For TMT5, you need to use uMCEPlayer5.exe and for PDVD11, you need to use PDVDLaunchPolicy.exe.
I like external player to playback blu-ray disc and BD ISO for bitstreaming and enjoy all the original BD menu options. I still can enjoy XBMC for front-end and playback all other files.
but that assumes you have media center remote, I use my android phone with xbmc remote so those solutions don't work I assume?
robl45 Wrote:but that assumes you have media center remote, I use my android phone with xbmc remote so those solutions don't work I assume?
MCE remote is very cheap (
OEM HP MCE KIT REMOTE), and I would not want my kid to use my $499 Android phone as a remote either.
i just install XBMC PRE-EDEN 11.0 (1.1.12) With DSPlayer and like magic in harry potter evrything is working no more coppy movies !!!!
Solved !
if you have coppy or slow movie and you want to make it better just install the newest vertion of XBMC With DSPlayer !
Link :
http://dsplayer.passion-xbmc.org/
