2012-01-04, 23:30
Hi there,
I new in here, but I haven't been able to find an answer to my question by searching, so bear with me
I am trying to install XBMC Live 10.1 via USB made from the unetbootin. I've done this before, without problems, but this time, I experience the following.
Everything is OK, until I select Install System. Here, it copies files, and when it reaches 13%, I am again presented with a menu, where I can select various options, including "OKĀ“, and "FINISH INSTALLATION". Both options will restart the filecopy, and respawn the options menu.
Any takes on this?
This system is quite similar to the old system, yet with these changes:
RAM: 3GB (old system 1GB)
CPU: 3,2 GHz Pentium 4 (old system Pentium 4 2,6GHz)
Same GFX card
HDD: 500GB Sata II (old system 320GB Sata 1)
This is really annoying, as the hole family uses the mediacenter...can anyone please help
Any takes on this?
Same GFX card
