Yes, probably. But only if you update XBMC to Gotham. The add-on uses the old (unreliable) fix in Frodo.
(2013-11-01, 14:50)Carb0 Wrote: [ -> ]Great. I updated the add-on. It should automatically use the "|User-Agent=" method in Gotham and the old fix in Frodo.
0.5.6
- Fixed live games in Gotham (all platforms)
- Changed minimum API for python to 2.1
Thanks Carb0! I can confirm 0.5.6 auto-updated and is working perfectly on my Linux machine with XBMC built from git, e51b7b51e2952255179cda55a875c816153003eb (Oct 28, 2013)
I am having some buffering issues for the last 2 days? Anbody else having this problems? I presume that the problem is not in plugin, but the load on NHL servers. Anyway just wanted to check to make sure. I ahve 14 Mbit connection. I think that should be enough?
Thank you guys for all the work.
Edit. Never mind. The game after was working without problems.
Hi guys, I am trying to add NHL Gamecenter to my apple tv 2. It is jailbroken with season pass on 5.2 (untethered). I have xmbc installed. Is there anyway I can watch the games without an NHL Gamecenter account?
If so, could you give me a run down of what to do, it is pretty hard navigating through 73 pages of forums.
No, it doesn't work without a NHL Gamecenter account. You could have read the first sentence of the first post and you'd know it.
Howdy Carb0.
Wondering if you could add the french stream for the Canadiens to the add-ons?
Did a bit of checking around an all that changes is the URL's is FR is added to the URL "/nhlfr/canadiens"
For some reason they only broadcast the French stream on the browsers (I"m a GCL subscriber obviously) and even via my X-box or the regular GCL App on the ATV2 there is no way so get the French, so I just end up hooking my laptop up to my TV which is a pain and watching via Chrome haha.
(2013-11-03, 16:09)Carb0 Wrote: [ -> ]No, it doesn't work without a NHL Gamecenter account. You could have read the first sentence of the first post and you'd know it.
So I have to pay $169.99
Mgooding9 - yes, that is correct.
New to XBMC, really liking it. Installed Gotham and gamecenter live is working well. One question, I often don't get the opportunity to watch a game from the start time, usually join about an hour after (after the little one goes to bed) if watching in a web browser I can join the game live then move it back to the start. Is there a way to do this with this addon? Or a way to just start it at the beginning ( I think the appletv app does this but not 100% sure)? Or should I just start gamecenter when the game starts and hit pause (will this even work?)? Thanks in advance and my appreciation for all of your great work!
(2013-11-04, 05:06)l3wdoo Wrote: [ -> ]New to XBMC, really liking it. Installed Gotham and gamecenter live is working well. One question, I often don't get the opportunity to watch a game from the start time, usually join about an hour after (after the little one goes to bed) if watching in a web browser I can join the game live then move it back to the start. Is there a way to do this with this addon? Or a way to just start it at the beginning ( I think the appletv app does this but not 100% sure)? Or should I just start gamecenter when the game starts and hit pause (will this even work?)? Thanks in advance and my appreciation for all of your great work!
I don't think this is supported. I use browser to watch games already in progress from the beginning. Maybe someone else can confirm.
BTW... On my windows 7 64bit after upgrading Frodo to Gotham alpha 9 I had issues with satisfying python 2.1 dependency? The workaround was to manually overwrite *.py file provided by avens19 post #718/pg72. Not sure how to upgrade xbmc to python 2.1 API which is required now.
Also thank you for getting this working again...
I downloaded Alpha 9 but it says that NHL Gamecenter 0.5.6 is broken and I can't do anything with it. How would I go about updating the addon?
---Edit---
I uninstalled and reinstalled XBMC and now the addon appears to be working.
Watching the pregame for the Rangers/Ducks and things are looking great. Awesome work to everybody who go this back up and running!!!
(2013-11-05, 02:34)ktrdsl23 Wrote: [ -> ]Watching the pregame for the Rangers/Ducks and things are looking great. Awesome work to everybody who go this back up and running!!!
Not if you are a Rangers fan :-\
I am running xbmcbuntu with add-on , no issues now ( thanks to all )
I just recently purchased a Pivos / Anroid box
running Linux xbmc version (android is gone ) from pivosgroup
installed gamecenter
can get to Live/Condensed listing
but as soon as I try to go into either of them, I get script error at the bottom
is there way to fix this ?
(2013-11-05, 03:05)bry- Wrote: [ -> ] (2013-11-05, 02:34)ktrdsl23 Wrote: [ -> ]Watching the pregame for the Rangers/Ducks and things are looking great. Awesome work to everybody who go this back up and running!!!
Don't blame Carb0 for that poor design decision.
