Anyone know why XBMC crashes/disappears when I click on the game feed? It doesn't happen every time; usually only when I don't click the feed right away or I switch between home & away.
Also, is there a way to disable the time remaining on the video player (so as to avoid spoilers for archived games)?
Thanks again Carb0 for continuing to develop and support this - by FAR the best Gamecenter app.
I'm running on Frodo and am experiencing extreme buffer pauses today for the Van/Car game. I'm having thing pause and buffer approx every 30-90 seconds. Is there a way to increase my buffer size so that I queue up a couple minutes worth before it actually plays?
Hi carb0. I'm writting an addon for a service that uses the same system that nhl.
On this you use the _ced. parametre and appletv header to get key information.
It works with _android, _ipad, etc. but i can't get the correct header information to an accepted key.. it gives me always 403.
How did you find the header information for ced? thanks
Just a note for those who want to save some $$. NHL gamecenter is available for international subscribers for $99. all you need to change is your DNS settings. I am in ottawa and I just used the settings on tunlr.net and saved $70. It also unblocks almost every game for free (cheaper alternative to VPN)
when i tried to use tunlr.net i get a message saying 'could not connect to network server' however my internet browser on the same machine will let me stream games fine. I'm using Gotham Alpha 10 and the add-on would stream before i used the tunlr.net DNS but it was very very stuttery.
Suddenly, all live games are not giving option of home or away. Popup says waiting for video feed
Same here all live games say waiting for feed. I uninstalled the addon and now I can't reinstall it. Says incompatible and all options but change log are greyed out. I'm on Gotham alpha 10.
I was able to get live games going again by Installing frodo 12.2, then force refreshing Carb0's add on (it said broken initially), then reinstalling Gotham alpha10.
Any updates on this. I can't seem to watch live games. Running 12.3 test version. Just installed everything yesterday.
EDIT: never mind. I see the fix. What are the negatives to upgrading to Gotham?
Been a while since I used my Raspberry Pi with this. I just installed this again and it doesn't work - I get 1 second of game audio and sometimes a flash of the game, then it kicks me out with an error message. I think it's time to accept that this may be finished.
I was watching games on my Raspberry Pi last night without any issues? I'm on Raspbmc running XBMC 13 alpha 11.
Turns out I'm on 12.2 despite automatically getting the most recent update? How do you have 13?
Since gotham is not officially released as stable yet, it is not recommended unless you are comfortable running unstable, potentially buggy software.
That said, running great on gotham compiled from git on Ubuntu 13.10 mini-itx htpc
*UPDATE* - got it working my simply selecting to use the 'dvd player' rather than the 'omx player'
