Full Version: Cant Connect To Web Interface!
Hello,
I just built an xbmc computer. It is running windows 7 64 bit. I got XBMC installed and it can see all the movies and stuff stored on my other computer. However i enabled the HTTP web interface and neither the other computer nor an ipad can connect to it via web interface. The web interface does not work. I shut off the windows firewall, turned on all the sharing options, used a few different ports (21, 80, 8080) Nothing worked.
Anyone have any ideas?
Im using the latest release (not beta) and using the Aeon skin
Thanks so much for your help in advance.
