2012-01-08, 19:59
I'm running Ubuntu 11.10 with the latest XBMC PVR + TVHeadend 2.12.99~pulse4 on an Intel i3 system making use of the integrated graphics. Today I installed the drivers which allowed XBMC to make use of VAAPI. I originally installed them from the xorg-edgers PPA before finding that there was a bug as in this thread:
http://forum.xbmc.org/showthread.php?tid=118955
I followed the instructions there and it was solved by downgrading to mesa 7.11. Either before this or straight after (I can't remember) I had tested LiveTV and found it working fine. I then watched a h.264 encoded movie and that worked great too, with the hardware acceleration A-Ok.
But now when I try to view TV with VAAPI enabled XBMC crashes with this error:
http://pastebin.com/DQ1TXdXd
and all objects on the desktop (terminal windows, file system browser, taskbar) are shown as a blank white box. However, this is purely a display issue as I was still able to issue a reboot command from within the terminal.
Any ideas? Thanks.
Any ideas? Thanks.
