Skins Support
Skin Archive
Transparency!
> Fanart Images As Background?
Full Version:
You're currently viewing a stripped down version of our content.
View the full version
with proper formatting.
lenn1
2012-01-08, 22:54
Is it possible to set the collected fanarts in the database e.g. movies as a multi-image background?
Would be nice!
Great job so far! Thx for your hard work!
ronie
2012-01-09, 00:02
yes you can.
Settings > Skin Settings > Backgrounds
select the 'Multi Image' option for each section you want to apply it to.
and select the folder containing all your fanart images.
tip: you can use the artwork organizer script to copy all your fanart to one folder.
lenn1
2012-01-09, 00:26
Ty!
Skins Support
Skin Archive
Transparency!
