Hey, i'm trying to get PVR working, and therefore i need a PVR supporting skin.
I don't like the standard XBMC skin very much... So far i have been using Alaska, but this doesn't support PVR - So i need to change :/
What skin can handle this?
rasmuskarlsen Wrote:Hey, i'm trying to get PVR working, and therefore i need a PVR supporting skin.
Take a look here, you'll see supported PVR Skins with " Live TV " yes or no.
http://wiki.xbmc.org/index.php?title=Com...n_features
Hi all,
while this
shows a lot of skins with PVR support it seems - after checking some of them that are marked "Live-TV enabled" - that most of them don't feature full PVR support like Confluence (seems to be something like a reference skin in PVR support) .. reFocuc for example is really nice but the PVR support seems to be at the very beginning though it's already marked as Live-TV enabled ...
Could somebody give a hint, which skins have
fullfeatured PVR support atm (means OSD with for example record button and so on ?)
Thx
LastCoder
LastCoder Wrote:Hi all,
while this
Could somebody give a hint, which skins have fullfeatured PVR support atm (means OSD with for example record button and so on ?)
Thx
LastCoder
Cirrus Extended v2 should be almost complete. Give it a try.
