Full Version: problem with building Music library
Dear all,
I'm having trouble building the music library since Eden beta is installed. The content are stored on a WD MyBook Live NAS drive and the NFS is in use. It works just fine for Videos but it's being crashed every time I try to build the music database. Is it a known bug or something? Details with the log are attached below:
H/W  : ATV2 (black)
Ver. : 4.4.4
xbmc : Eden Beta (installed from unstable-repo)
log  : [url]http://pastebin.com/FSegDD4U[/url]
Any comment form anyone? cheers!!
Try refreshing the tags on the last album in the logfile. There has been problems with id3 v2.2 tags in some music causing the scraper to bomb.
MacUsers Wrote:Dear all,
H/W  : ATV2 (black)
Ver. : 4.4.4
please see this post:
http://forum.xbmc.org/showthread.php?tid=116373
it would be great if you can offer your time to help the devs to solve this problem.
Yes! found that post just after posting mine. I'm gonna try those suggestion(s) in the evening when I get back home. Cheers!!
g-off Wrote:Try refreshing the tags on the last album in the logfile. There has been problems with id3 v2.2 tags in some music causing the scraper to bomb.
Didn't work - refreshed using iTunes but still the same result. the symptoms are exactly same as the other thread, mentioned above. Cheers!!
