2012-01-09, 14:58
![Full sized picture Image](https://github.com/dersphere/plugin.audio.radio_de/raw/master/icon.png)
I'm happy to announce my newest addon "Radio". It is a music plugin to provide quick access to more than 30000 international radio broadcasts (powered by the websites http://www.rad.io (English), http://www.radio.de (German), http://www.radio.fr (French), www.radio.pt (Portugal) and www.radio.es (Spain)). I hope it is a good replacement/addition for the shoutcast and icecast addons. Please note that there are more then just "only internet radio stations" accessible via this addon.
You can browse the stations via genres, topics, countries, cities and languages.
You can also put any station to the list of "My Stations" (with context menu) for quick access.
Upstream code location: https://github.com/XBMC-Addons/plugin.audio.radio_de
The addon is present in the official kodi addon repository in two flavours: py2 (gotham ~ leia) and py3 (matrix). Development targets the matrix branch while backporting fixes to the gotham branch. Versions is equivalent (although python3 only) to the version in gotham - thus uses a version system consisting of PEP440 local version identifiers (x.x.x+matrix.x).
Changelog:
Original author was sphere. The addon is now maintained by enen92.
Thanks,
enen92
Mod edit - the addon has now been forked by @fivebanger, and you can get it from his repo:
Repo - link (if it opens as a GH page, click the "view raw" link to download the zip).
Radio addon - link
Changelog:
v3.0.3+matrix.6 (1/5/2020)
- [fix] Custom stations if the url is not a playlist
- [new] Spanish website radio.es and improved translations
- [new] screenshot support for addon-website
v3.0.2+matrix.1 (1/5/2020)
v3.0.1+matrix.1 (13/4/2020)
- [new] Use internal playlist resolver also in custom stations
v3.0.0+matrix.1 (12/4/2020)
- [new] Automated submissions to matrix
- [new] Python3 only version
- [new] New language layout and other matrix fixes
- [fix] Playlist based stations
- [fix] Ratings
v2.4.2 (9/2/2020)
- [add] sort methods for categories
- [add] setting to prefer http connections over https if http streams are available
- [fix] use sys.version_info[0] for compatibility with python2.6
v2.4.1 (31/12/2019)
- [fix] Custom radio tracks
v2.4.0 (29/12/2019)
- [new] Use radio API v2
- [fix] Remove dead code
- [new] Add radio.pt
- [new] Page listings
- [new] Better quality logos
- [new] Hide fanart setting
v2.3.5 (25/12/2019)
- [fix] Artwork not available in player
2.3.2 (07.06.2017)
- fixed playback
2.3.1 (15.02.2015)
- updated translations
2.3.0 (29.11.2013)
- added playback for asx playlists (e.g. BBC)
- added blayback for xml playlists
- improved station search
2.2.1 (11.08.2013)
- added new addon.xml tags
2.2.0 (11.03.2013)
- better station logos
- better add-on icon
- changed to xbmcswift2 v2.4.0
- small code improvements
- use random server on playlists (instead first one)
- update translations
2.1.3 (26.12.2012)
- fix unicode error
- change to xbmcswift 1.3.0
2.0.2 (16.12.2012)
- fix no genre available (resulted in script error)
2.0.1 (03.11.2012)
- added migration code to convert old my_stations to new system
- fixed unicode in custom station title
- Added spanish translation (thx to Patrizia)
- Added french translation (thx to stombi)
2.0.0 (unreleased)
- Code Rewrite
- Possibility to add custom (user defined) Stations
- Thumbnail View (You can disable in the add-on settings)
- Change to the xbmcswift2 framework
- New Icon
- Possibilty to add Stations to the XBMC Favorites
1.1.1 (Unreleased)
1.1.0 (13.07.2012)
- New My Station logic (listing should be much faster after initial migration)
- Small fixes
1.0.7 (unreleased)
- Fixed: error in language_guessing
- Fixed: routes (fix xbmcswift-xbox usecase)
1.0.6 (05.03.2012)
- Fixed: error if a station was added to the list of mystations but has become unavailable
- Improved error catching
- Improved: Show bitrate in "kbit/s", not "B"
1.0.5 (26.02.2012)
- Fixed .m3u playlists with empty lines (thx to Malte_Schroeder)
1.0.4 (18.02.2012)
- Fixed python <2.5 error
1.0.3 (07.02.2012)
- added workaround for streams with .m3u and .pls files
- changed: show full context menu
1.0.2 (29.01.2012)
- Fix error with UTF-8 characters in search string
1.0.1 (13.01.2012)
- Initial Release
Thanks,
enen92
Radio addon - link
