Full Version: [RELEASE] Radio Add-on (rad.io, radio.de, radio.fr, radio.pt, radio.es) Music Plugin
sphere,
I tried to install this addon, but it says "downloading 0%" and then just stops and puts me back to he menu.
(xbmc 12 frodo rc3, windows xp)
here's my log: http://xbmclogs.com/show.php?id=3785 any idea what might be up?
Nothing to see in your log. But there were some issues in the official add-on repository in the last days, just keep trying again.
I have a Problem.
Initial Setup where i have configured the XBMC. (12.0 RC1)
- Video Lib
- Music Adons (Radio)
Here is everything OK and all the Stations that i have under "my Stations" are running perfect.
- Welle1 Salzbur
- Technobase FM
- FFH Rock Over Germany
Now i have updated the XBMC to 12.1
Problem:
- if i start FFH Rock Over German hangs the complete XBMC / no audioplaybay (No Response from the Application)
- the other Stations run correctly
Now i installed the actual nighlie (13.0): same Problem
Downgraded to 12.0: same Problem
Downgrade to 12.0 RC1: FFH Digital Rock is working perfect
OS: Win7 x64 SP1 all Updates /
Intel E8400 Asus P45Q-E
Avast Antivirus
I'v tried to delete the Radio Addon Folder (C:\Users\USERNAME\AppData\Roaming\XBMC\addons\plugin.audio.radio_de) and install the addon again: no change
Has anybody a idea whats the problem?
thanks
I don't think that this is add-on related but XBMC related.
I will have a look to this station later today.
Hello!
I'm very often using this plugin and like it.
It the moment I try to find out how the architecture of xbmc is handling artist and title information, because using this plugin with my favourite station always artist - title is stored in the artist variable.
http://forum.xbmc.org/showthread.php?tid...pid1373849
I haven't found a component or forum like infomanager yet and I can't belive the skin is doing the handling of title information.
thanks for the excellent plugin. Unfortunatly one of my favourite stations, Triple M Sidney, is missing, which I find without problems on radio.de wev site search. When I search stations inside the add on with term "triple" it finds just "Triple R" and "Triple J" but not the "TripleM" stations like on the web interface. What do I wrong?
Thanks and best regards from Bavaria
sorry I can't reproduce. I am able to find (and playback) "Triple M Sydney". Please check again, and if you then still are not able to find it I would need your xbmc.log.
regards,
sphere
Hi sphere,
thanks for the reply. I must have been blind. I realized that search is case dependent. Once I entered Triple with upper case T it worked. Have a good weekend
best regards
wmeinolf
cool, thanks for reporting back.
Hey,
Under local stations all the BBC stations are dead?
Has there been a change to their site/streams? Could the BBC stations be re-added or is this not possible at the moment?
Cheers
Pat
Edit:
Looks like real radio is missing from UK stations / City station and Local stations too?
All BBC streams are either missing or dead?
They seem to work well on other plugins so I assume they are active somewhere and must be a bug with the plugin/site Smile
Could you try again and if it still doesn't work please send me a xbmc.log.
Btw, most bigger stations (like BBC) use playlists which include multiple stream-urls, if the add-on detects such a playlist it chosses a random stream-url. So if any station is not working correctly give it another try Wink
regards,
sphere
*obsolete*
I'm looking at AWX 0.6.4 web-interface for XBMC 12.1 and seems that support the addons browsing that allow you to explore radio from a browser.
Is there a way to add a more control from web? I mean if I push "Search station" on the browser the input form appear on the xbmc PC screen:
would it be possible to add and use the input form on the web page?
where do I have to look?
any advice is really appreciated, BR.
(2013-04-24, 14:46)summer88 Wrote: [ -> ]I'm looking at AWX 0.6.4 web-interface for XBMC 12.1 and seems that support the addons browsing that allow you to explore radio from a browser.
No, (afaik) this isn't possible due to XBMC api limitations.
This happens with radio.de
When I do
PHP Code:
<control type="label">
posx>850</posx>
posy>10</posy>
label>$INFO[Player.Title]</label>
control
It displays Song name of the station but how can I display currently playing station name?
