2013-07-16, 01:38
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
2013-07-16, 23:28
(2013-07-16, 01:38)privado Wrote: [ -> ][solved] issue. Its actually a bug in openelec 3.1.2, temp fix is here: http://www.openelec.tv/forum/74-music-ma...info-stuck
Thanks for reporting back!
2013-07-28, 20:25
Thanks for the great plugin.
Just one question:
why some stations do not show up even if they are listed in rad.io ?
For example, this one:
http://latvijasradio1.rad.io/
It does not show up when I search for stations in my location, and also it is not found under stations by country ->Latvia, and also it does not show up when I search "Latvijas" (although some other Latvian stations show up and play fine).
Just one question:
2013-07-28, 20:55
(2013-07-28, 20:25)midix Wrote: [ -> ]Thanks for the great plugin.
Just one question:
Please try with the Android or iOS App. This add-on uses the same API like them. If you are also not able to find this stations there you could try writing an email to radio.de (or rad.io).
Sorry - I have no access to the content itself and can't add, fix or change stations.
regards,
sphere
2013-07-28, 22:01
Can I add the missing stations manually?
In http://wiki.xbmc.org/index.php?title=Add-on:Radio I see:
"Possibility to add custom (user defined) Stations"
but there is no detailed instructions on the Wiki.
With the help of this thread I found the file
addon_data\plugin.audio.radio_de\.storage\my_stations.json
but there already are listed some stations which I added from XBMC and I don't want to mess something up.
What is the format of custom stream descriptions to use in my_stations.json file?
For example, I see
For my missing radio station I can find stream urls and bitrates. I have the choice of the following:
mms://lr1w2.latvijasradio.lv/pplr1
or
http://lr1mp1.latvijasradio.lv:8012/
(the second is mp3 with bitrate 128 kb/s)
And thumbnail is
http://www.latvijasradio.lv/public/asset...col_sm.png
But I have no idea how to fill the "id", and what are those "1375031852.2642119" numbers at the end of the JSON array?
For example, I see
"13965":[{"rating":5,"name":"Radio Skonto","thumbnail":"http://static.rad.io/images/broadcasts/",
"stream_url":"http://skonto.ls.lv:8002/mp3","current_track":"",
"genre":"Eclectic","bitrate":96,"id":13965,"description":""},1375031852.2642119]
or
And thumbnail is
2013-07-28, 22:12
You don't need to add something to the JSON yourself.
Just open up "My Stations" and choose "Add Custom Station" - You will be asked for the name, an icon (optional) and the stream-URL.
2013-07-28, 22:32
Oh, thanks alot. I added the station in "My stations", and manually copied the URLs into my_stations.json to avoid typing in XBMC.
Now everything works fine.
There is just a problem with visualisation - it just rotates and doesn't move bars corresponding to the music.
2013-08-15, 12:22
Great plugin thanks!
2013-08-21, 20:55
Your fucking App smashed my whole RaspBMC. Fuck you for your App. Upload it as a beta when you don't know what you do!
2013-08-21, 20:58
Welcome to xbmc.org. Look forward to more of your valuable input and witty anecdotes.
2013-08-21, 20:59
(2013-08-21, 20:55)Buzzinhomer Wrote: [ -> ]Your fucking App smashed my whole RaspBMC. Fuck you for your App. Upload it as a beta when you don't know what you do!
Youre welcome
2013-08-21, 21:06
What a first Post. I don't have any problems with this great Addon. I Love it.
Please ignore the post of him...
2013-08-21, 23:29
So you won't be donating then?
2013-08-21, 23:47
Welcome to the XBMC forums
Congratulations. You've earned a two week ban on your very first post.
2013-09-10, 00:22
Hi sphere
I have a problem, maybe you can help me.
I use "OpenELEC Stable - Generic i386 Version:3.0.6" and your add-on.
Some Radiostations didn't work.
Error Log here:
http://xbmclogs.com/show.php?id=56874
At the Line 255 you see starting the issue.
Please can you please have a look, if is the fault come from your addon?
The Radiostation ABC Lounge stream url http://listen.radionomy.com/abc-lounge works normally.
Thank you in advance for your effort.
Lejla
Error Log here:
Lejla
