The Radiostation that isn't working is
YFM. (South African Station) I think it is not a problem with the plugin, on radio.de it doesn't work as well.
I would love to test some new functions, the problem right now is that I am travelling a lot and just get all 14 days the possibility of proper internet network. If that isn't a problem then you are welcome to send me a pm.
Regards
MeC!as
Hey Sphere,
I really like your addon so far very much. Since Shoutcast is kinda broken for ages already, this is by far the best radio plugin.
I just wanted to report a problem with one of my favorite stations:
181.fm - The Buzz
In the list of stations, its shown, but without bitrate. You can play it though, but upon launch, it seems to switch to another station, 3WK underground radio. So basically you won't get 181.fm - The Buzz. Other 181 sub stations seem to work just fine though.
Could you look into this?
Thanks,
boba
boba23 Wrote:I just wanted to report a problem with one of my favorite stations:
181.fm - The Buzz
MeC!as Wrote:YFM. (South African Station) I think it is not a problem with the plugin, on radio.de it doesn't work as well.
Both problems are not related to the plugin itself - I reported it to the aggregator - they should be able to report it to the stations.
regards,
sphere
sphere Wrote:Both problems are not related to the plugin itself - I reported it to the aggregator - they should be able to report it to the stations.
I just received the message that both streams got fixed - they should work "in the next hour" - thanks to the good radio.de support.
regards,
sphere
sphere Wrote:I just received the message that both streams got fixed - they should work "in the next hour" - thanks to the good radio.de support.
regards,
sphere
Great news man, thx a lot :-) Is there any E-Mail or other contact to report defect streams to radio.de in the future?
boba
boba23 Wrote:Great news man, thx a lot :-) Is there any E-Mail or other contact to report defect streams to radio.de in the future?
boba
Yes:
[email protected]
But my addon is not official supported by them. To be sure that it isn't an addon-related issue it would be better to let me check first.
Especially because there seems to be a xbmc bug which prevents some shoutcast-type streams to be played (
http://trac.xbmc.org/ticket/12729) correctly.
regards,
sphere
Alright man ... btw I'd have another suggestion, that would make the addon even better in my eyes. Would it be possible to add some more sort options? I remember that the original shoutcast addon could sort by the number of listerners. You think that'd be possible? And maybe by the bitrate the stream plays at ...
boba
boba23 Wrote:I remember that the original shoutcast addon could sort by the number of listerners.
No, this is not possible because radio.de is only an aggregator - it just gets the stream urls from the broadcasters - they don't know how much listeners a broadcaster has.
boba23 Wrote:And maybe by the bitrate the stream plays at ...
This is already available and should be visible. See the right column while in list view - this is the bitrate in kbit/s.
regards,
sphere
I got the following error whatever item I select in the list.
12:53:40 T:2954791792 M:2168549376 NOTICE: Radio addon: show_station_categories started with category_type=topic
12:53:40 T:2954791792 M:2168422400 NOTICE: Radio addon: __get_language has first run with xbmc_language=english
12:53:40 T:2954791792 M:2168561664 ERROR: Error Type: exceptions.AttributeError
12:53:40 T:2954791792 M:2168561664 ERROR: Error Contents: 'Plugin_mod' object has no attribute 'open_settings'
12:53:40 T:2954791792 M:2168532992 ERROR: Traceback (most recent call last):
File "/home/sdruon/.xbmc/addons/plugin.audio.radio_de/addon.py", line 286, in ?
plugin.run()
File "/home/sdruon/.xbmc/addons/script.module.xbmcswift/lib/xbmcswift/plugin.py", line 326, in run
self.dispatch(self.path)
File "/home/sdruon/.xbmc/addons/script.module.xbmcswift/lib/xbmcswift/plugin.py", line 129, in dispatch
return view_func(**items)
File "/home/sdruon/.xbmc/addons/plugin.audio.radio_de/addon.py", line 121, in show_station_categories
language = __get_language()
File "/home/sdruon/.xbmc/addons/plugin.audio.radio_de/addon.py", line 276, in __get_language
plugin.open_settings()
AttributeError: 'Plugin_mod' object has no attribute 'open_settings'
12:53:40 T:3014592384 M:2169196544 ERROR: GetDirectory - Error getting plugin://plugin.audio.radio_de/stations_by_category/topic
12:53:40 T:3014592384 M:2169196544 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.audio.radio_de/stations_by_category/topic) failed
12:53:53 T:2954791792 M:2169843712 NOTICE: -->Python Interpreter Initialized<--
12:53:57 T:2954791792 M:2169135104 NOTICE: Radio addon: show_root_menu start
12:53:57 T:2954791792 M:2169135104 NOTICE: Radio addon: show_root_menu end
12:54:02 T:3014592384 M:2165899264 NOTICE: Storing total System Uptime
I have v0.0.5 of teh plugin and dharma on ubuntu 11.10.
Any clue?
Thx in advance
I Run the Radio add-on on XBMC on a ATV2
Can anyone tell me the button combination I have to push to store a station in my favorite list ?
(2012-03-18, 18:52)Frank595 Wrote: [ -> ]Can anyone tell me the button combination I have to push to store a station in my favorite list ?
You can add stations to your list of "My Stations" by pressing the context menu (press and hold menu on ATV2-Remote) while this station is selected and chose "Add to My Stations".
You can also add stations to your xbmc-wide list of favorites by pressing the context menu and while this station is selected and chose "Add to favorites".
regards,
sphere
While the install (in Eden final )seemed to go fine, I can't find this add-on anywhere (should I see it on the main menu or in Music) ?
In the debug log I see...
18:00:42 T:1780 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:06
18:01:46 T:3148 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 28
18:01:46 T:3148 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
18:01:46 T:3148 ERROR: XFILE::CFileCache:
rocess, error 0 seeking. seek returned -1
18:02:09 T:2976 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 28
18:02:09 T:2976 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
18:02:09 T:2976 ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.xbmc.org/addons/eden/script.module.xbmcswift/script.module.xbmcswift-0.2.0.zip.md5>
18:02:24 T:2976 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 28
18:02:24 T:2976 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
18:02:44 T:2188 WARNING: XFILE::CFileCurl::CReadState::FillBuffer: curl failed with code 28
18:02:44 T:2188 ERROR: CFileCurl::CReadState::Open, didn't get any data from stream.
(2012-03-25, 18:11)r2504 Wrote: [ -> ]While the install (in Eden final )seemed to go fine, I can't find this add-on anywhere (should I see it on the main menu or in Music) ?
when installed you should see it in addons/music or music/addons (depends on your skin).
Regarding your log: Looks like you have network problems, do you have proxy settings enabled but have no proxy?
regards,
sphere
