Full Version: [RELEASE] Radio Add-on (rad.io, radio.de, radio.fr, radio.pt, radio.es) Music Plugin
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
Feature Request
First of all Thanks for this gr8! Addon.
I would have a "liddle" feature Request:
Would be gr8 if it would be Possible to be abel to login to the personal Radio.de account. To sync "my Stations" with several XBMC/Kodi and other Devices.
I have a Account on Radio.de to manage "my Stations" This works fine on my Smartphone. As soon as i'm logged in, i have my Favoret Channels/Stations on my Finertip.
In Kodi i have to set them manualy and multiple times for different Installations (which is a bit tedious). Also if i do a Fresh Install i have to do the Work again.Sad
So would be gr8 if you could alow to log in.
Regards
Hello, I've been trying to find an addon to allow me to play Radio Paradise in my Windowz 10/Kodi 15.2 HTPC. I came across this addon installed it & searched to find Radio Paradise. But when I try playing it, it shows to be working, but no audio . RP uses mp3 stream, so I should think there shouldn't be an issue? Other stations work fine.
Hello.
It is a great add on, I used it all the time.
After reinstall of Kodi, and recovering it's data,
all add ons are gone, and when I try to reinstall radio it reports failed to install dependency.
What are it's dependencies and how can I fix it?
I have a problem with your addon.
I can start it on my HTPC and I can the see categories ("Sender in Ihrer Nähe", "Tipps der Redaktion", ...). But I cannot select one of the categories, if I try, nothing happens.
On another PC it is working without a problem (both on KODI 15.2)
I already tried reinstalling and deleting the folder in Kodi userdata.
Can you please help me?
Thank you.
I've also been having the exact same issue as described above since yesterday.
A fresh installation of Kodi solved my problem.
I am using the RADIO addon with kodi 15.2 on an Intel NUC5i5RYK running Mint 17.3/Cinnamon 2.8. I like it and use it a lot, but I have a recurring problem with one particular station: a campus radio station (WKCR.org), which broadcasts from Columbia university in New York City. Very often (but not every time!) the station fails to play. Other stations play just fine, but WKCR fails repeatedly. What can I do?
(2012-01-09, 14:58)sphere Wrote: [ -> ]Hi,
snip
If and when you release another update, could you please add a radio station.
88.7 CIMX
It's a Canadian station that broadcasts to Detroit USA. Most listeners know it as 89X.
Here is a link to their live internet feed - http://www.89xradio.com/Music/Listen-Live
Cant get it to install. On Android or Windows, either 14.2 or 15.2
error log says this: 15:02:54 T:9844 ERROR: CAddonInstallJob[plugin.audio.radio_de]: failed to download special://home/addons/packages/plugin.audio.radio_de-2.3.1.zip[/COLOR]
Is a kodi server down or something else? Is there another source other than the built in kodi one.
Is this not working for anyone else? All of a sudden, the one saved stream that I listen to no longer plays. If I go to the source page, it plays fine. Source is KTCK 1310.
(2016-01-04, 17:50)garydebergerac Wrote: [ -> ]Is this not working for anyone else? All of a sudden, the one saved stream that I listen to no longer plays. If I go to the source page, it plays fine. Source is KTCK 1310.
I can't get any of the streams I try with this addon to work either on Kodi 15. I wound up uninstalling it. Undecided
I'm down to 2 internet radio streaming addons now, and who knows how long they'll last.
I'm kind of thinking the handwriting is on the wall as far as Kodi is concerned. Both video and audio streaming addons have been dropping like flies. All the good addons are disappearing fast.
I'm thinking it's time to replace my RPi's with computers capable of running a full OS so I can use a browser to watch YouTube etc and listen to online radio... Undecided
Too bad. :-[
Hi there,
I was looking for a way to add station radio logo, because they are missing (at least for the ones I am listening to).
Could some be so kind and explain to me how to do this.
Thank you in advance
Station 97.5 virgin radio London is on the list but it is silent when selected
Hi really like the add-on. Just can't seem to figure out how the Add custom radio works. Specifically what needs to be put in as stream url? Do I need a .mp3, .pls, .strm? Can you provide some insight please?
Trying to add an oldie station http://www.megatoncaferadio.com/. Or do they need to register themselves with rad.io?
Thanks for any help, thoughts, suggestions.
Cheers
Rick
(2016-02-06, 18:41)rickyroqy Wrote: [ -> ]Hi really like the add-on. Just can't seem to figure out how the Add custom radio works. Specifically what needs to be put in as stream url? Do I need a .mp3, .pls, .strm? Can you provide some insight please?
Cheers
Rick
I don't know if this would work, but it states on their website:
Quote:TUNING IN
Streaming Radio Players, TuneIn and SONOS Wireless sound systems users.
Simply copy and paste the URL (link) below and add to your radio station player!
http://198.58.106.133/stream/megatoncafe.pls
