I have tried the Radio add-no on two setups so far today.
One Core2Duo laptop with Ubuntu 16.04 + Kodi RC3: network error all the way around 7am.
One i3 3225 PC with Ubuntu 16.04 + Kodi RC3: works at the first attempt, at 12am.
¯\_(ツ)_/¯
Now it's working again here as well... Let's see how long
For me, it works one day and network error the next day.
Works again since two days.
I've written a useful plugin to keep a radio stream playing as an addition to the Kodi Radio Plugin. It recovers the last playing radio station after the network connection has gone down, or after the system has been restarted. You find some info about it on:
http://tuxfrank.altervista.org/.
The plugin (zip) can be found at:
https://gitlab.com/TuXFrk/kodi.stream-ke...ree/master, use download zip.
I've been using the radio add-on for a couple of years now on my home stereo. Occasionally the radio station did not continue after a short network interrupt. Since this annoyed me, I decided to write a plugin that keeps monitoring if a stream is still playing. If not, it restarts the stream.
The basis functionality is quite simple. However, I also use the kodi mediaplayer to stream movies, play youtube films and music from my own NAS. Sometimes it did not work perfectly shortly after playing something else. It took several months of usage to get a perfect experience in all situations. I.e. After an album or playlist from my NAS has finished, the radio is started automatically (after 30-45 second or so, which gives me the chance to start another album or video before the radio kicks in). Now the music is always playing.
I've got Kodi installed on a hummingboard, that sometimes changed the audio output device from SPDIF to HDMI, so I've added a output channel checker to it as well. For me it's an essential addition to the radio app, I can imagine it is useful to others as well.
So therefor I decided to write a post here. Feel free to try it.
Suddenly, the addon shows only (up to) 100 results when browsing by genre or by country... I can see only the first 100 results and no more, but the search function works... Any idea?
Last version on android 7 (kodi 17.6)
Thanx.
Seem problem with me,only 100 stations are showing when i go to Browse by Country,United Kingdom,seems to only do the A's in the list,
not the other letters of the alphabet,A to Z.Using version 2.3.2.
The Radio plugin is why I use Kodi.
I'm having the same problem as above. Listening from the USA and now I can't find my two favorite stations, Radio Paradise out of California and RootsRadio.be out of Belgium. I hope that there is a fix soon.
(2019-01-16, 22:03)Whiznot Wrote: [ -> ]The Radio plugin is why I use Kodi.
To find them, I think you can use the search function, which is working, at least in my kodi.
The browse function, instead, is not working.
Why do all the categories in Radio end at the letter C. I want to access a station that starts CL but the list end at Ca. What is the solution?
Same problem for me. Jazz genre ends at "An"
Also with me Kodi in windows and LE with mini pc is crash and I don't know what is the real reason! may I noticed my internet speed today is quite slow!
I created a new custom page with new icons which onclick with the link of Radio from the addon (I got the link of stations through logs) and it works fine without make crash the Kodi!
what is the problem...why with addon it crashes and with custom page works stable?
Latest kodi developement version has kicked support for strings.xml so it is now not working anymore because you cannot see any text. 😔
Greetings,
Is it possible to access and re-use previous searches made within this add-on (search history)?
