(2021-10-21, 22:49)enen92 Wrote: [ -> ] (2021-10-21, 07:33)Jeffers24 Wrote: [ -> ] (2021-10-18, 07:28)Jeffers24 Wrote: [ -> ]If I paste the URL that is giving an error on line 522 of the Kodi log into chrome I get this error:-
@enen92
Is my issue being caused by the "two concurrent busydialogs" problem?
No your issue is likely due to outdated cacerts. I think one of the CA certs of letsencrypt has expired recently. See https://letsencrypt.org/docs/dst-root-ca...mber-2021/
In which Kodi versions / operating systems are you facing this issue?
Thanks for response, I hope all my platform details are contained in my Kodi log in this post:-
https://forum.kodi.tv/showthread.php?tid...pid3065492
If you need further info I am happy to supply.
Is the cacerts issue something I can fix in my W10 laptop?
If not will the issue be fixed, or is there way around the issue?
I installed the Radio addon on Kodi 19.3 running on Amazon Fire TV Cube. It seems to work, but after storing a few stations in My Stations, trying to play a station from the list in My Stations either crashes Kodi, or produces an error. Reading the log did not tell me much. This USED to work in older versions (before Matrix), and was very useful. Please fix it!
Hello,
on android TV, an error occurres while trying to open "My stations" folder (I may have put a wrong URL while creating a station in this folder).
See log file (at the bottom) :
https://paste.kodi.tv/owecugiwew
Thanks !
Hi. Thanks for maintaining the Radio app!
I have a quick question. A few weeks ago, I submitted a request to add
Streetsounds Radio to Radio.net. 14 days ago, they added it. It appears on both
Radio.net and
Radio.de. However, when I search in the Kodi app for "streetsounds", I don't get any results.
I noticed that Streetsounds Radio is incorrectly categorized as Jazz. I even tried browsing the Jazz genre, but couldn't find the station listed that way, either.
Any ideas?
Hello,
thank you for your answer and commitment.
I found one issue trying to stream web radios with Kodi for android TV :
- Kodi for android TV can't read the Flac stream from Mother Earth Radio (
http://server9.streamserver24.com:18800/motherearth), FLAC, 24bit 96 kHz,
while Kodi for PC has no problem with this stream (VLC for android TV can also stream this link).
Is that a limitation of Kodi for android TV ?
Thanks !
Okay, can someone please help me find out what I'm doing wrong. I'm trying to bind an autostart for this app to my remote. So when I choose Radio it starts the app and plays a certain radio station.
1. I've mapped the commands in my Harmony remote app
2. Using keymap edtor I figured out the key id of the button I mapped to this sequence. I used the button to use command "open radio app" under Global commands.
3. I opened Users\User\AppData\Roaming\Kodi\userdata\keymaps\gen.xml and edited the entry for this button to call: <key id="61480">PlayMedia(plugin://plugin.audio.radio_de/station/radiobob)</key>
Nothing I do opens the station. Nothing. Please help! The radio app starts fine but just stays at the main menu What am I doing wrong?
EDIT: I haven't got a clue what I did since I keep fiddling around but it started working as it should now.
I use the Radio App on several devices, mainly on my Pi via LibreElec.
A few days ago I noticed an issue with "Deutschlandfunk, Deutschlandfunk Kultur and Deutschlandfunk Nova".
These three german radio stations, constantly crashes kodi completely, forcing the system to reboot, when using my Pi's. On my main system with ubuntu, it crashes kodi, too.
This is the latest crashlog from it:
https://paste.kodi.tv/asuxeboyat.kodi
Other radio stations like "WDR 5" and "WDR 2" and so on are not suffering from this issue and you can also hear the radio station on its platform itself without any problem - very strange...
Thank you very much and best wishes!
Not working for me. Using 3.0.8+matrix.1 on kodi 19.1 in Win 10 x64. Get nothing but network_error notification with no log entry.
