Full Version: [RELEASE] Radio Add-on (rad.io, radio.de, radio.fr, radio.pt, radio.es) Music Plugin
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
I haven't heard anything about install issues, so I'm guessing the addon is maybe deprecated in 2022. Bummer.
Hi!
On my windows player radio is working well - but one crazy thing: With both Leia and Matrix the add-on is crashing after 6 hours!?! I mean exactly 6 hours!
Any idea?
Thank you for this addon.
It seems I can't watch bfmtv Paris.
I receive this error:
403 client error, forbidden for url:...
Thank you for any help.
Hi. Just discovered the radio app addon. I think it's great. However I've found that it crashes Kodi intermittently normally after 30-50 mins of playing. I've tried this on a clean Kodi 19.4 install on both a Nvidia TV Pro and a First Stick. Is this a known issue? Is there anyway round it? I'm using it with auto fanart (not sure where this comes from, probably one of the skin helper addons)
After a bit more testing, it seems to depend on which skin I use. The crashes happen in Titan Bingie but not Arctic Zephyr Reloaded. Maybe it's a memory issue?
Okay, the problem with radio not installing was not in radio itself but an old certs file in LibreElec so the repository was failing the authenticity check. Affected other plugins' updates and installs, too.
See this thread if affected and can't update LibreElec for whatever reason . . .
So I've got radio installed now, but now when I try to play a station, Kodi crashes back to the startup screen and restarts Sad At least it's a different problem.
Hello,
thx for this great add-on Smile
Unfortunately, I have just noticed that the add-on cannot play https://www.radio.de/s/radio-rtr
bash:
2022-12-18 19:52:05.162 T:20317    INFO <general>: initializing python engine.
2022-12-18 19:52:05.468 T:20317    INFO <general>: [xbmcswift2] Request for "/station/7855" matches rule for function "get_stream_url"
2022-12-18 19:52:05.468 T:20317    INFO <general>: [plugin.audio.radio_de] get_station_by_station_id started with station_id=7855
2022-12-18 19:52:05.468 T:20317    INFO <general>: [plugin.audio.radio_de] __api_call started with path=v2/search/station, param={'station': '7855'}
2022-12-18 19:52:05.469 T:20317    INFO <general>: [plugin.audio.radio_de] __urlopen opening url=http://api.rad.io/info/v2/search/station?station=7855
2022-12-18 19:52:05.607 T:20317    INFO <general>: [plugin.audio.radio_de] Unable to detect a playable stream for station
2022-12-18 19:52:05.608 T:19176   ERROR <general>: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.audio.radio_de/station/7855]
what about local stations catagory
(2022-12-22, 01:12)kobyboy Wrote: [ -> ]what about local stations catagory
I'm away from home until early January. I'll let you know after my return
I was able to access my network remotely. Going to through "Station by Country" leads to the same result
In <yourKodiIp:port>/#browser/music/plugin%3A%2F%2Fplugin.audio.radio_de%2Fstations%2Faz%2Fcountries%2FSwitzerland%2F12 you find
Both are the same Radio station; the first station fails but contains the correct logo, and the second does not have a logo but plays music.
Recently, I can't see any metadata / track- / artist name on the radio bob stations. e.g. "http://streams.radiobob.de/southernrock/mp3-192/mediaplayer".
"http://streams.radiobob.de/southernrock/mp3-192/mediaplayer|Icy-Metadata=1" doesn't work either.
Never had this on radiobob stations before and it's working fine in other apps (e.g. Linux radio applet or RadioDroid on android) - maybe someone has an idea what could be going on?
I have a feature request, or maybe it is just a support question. How do I remove a station from "My stations"?
Hi,does anyone have this addon working on kodi 20 nexus on windows?
Ive been using it on kodi 18 for a long while and absolutely love the addon but when i have updated to version 20 on 3 different devices,(all clean installs)1 android phone,1 shield tv and 1 windows,it still works on the android and shield but on windows it launches but if i click on any section within the addon it gives network error message and shows certificate verified failed in the log.
This only happens on windows for some reason.
If it should be working for windows i can post a log if that would help ?
Thank you for any help and also for the addon
(2023-04-08, 10:32)stringlefellow Wrote: [ -> ]Hi,does anyone have this addon working on kodi 20 nexus on windows?
Just opened Radio on my W10 laptop using Kodi 20.1, works okay for me
Thank you for your reply.Im not sure whats going on,as i mentioned its fine on other 2 devices just windows that it wont work
I will post a log file showing the certificate error to see if anyone can help
https://paste.kodi.tv/utabahijos.kodi
I have a request.
Can you add the following station to the Radio addon:
https://www.radio.net/s/live99fm
https://www.radio.de/s/live99fm
 This station is available on the radio website(s), but I do not see it in the Radio addon.
