Full Version: [RELEASE] Radio Add-on (rad.io, radio.de, radio.fr, radio.pt, radio.es) Music Plugin
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
Thanks for getting back to me and confirming this
Its really weird that yours will work on english but mine wont.
18.9 works fine set as english but any versions after that if i leave it as english in the settings then i get that error popup shown in the pic i posted and the certificate error showing like in the log i posted.
I have no clue as to why this is happening but im just glad i found a way to get it working
Hopefully the dev may be able to find the issue using all the info you have provided
I have a station I'd like to add
I recommend to you KAFN Arkansas Rocks FM on radio.net. https://www.radio.net/s/kafn-arkansas-rocks-fm
Please teach me how to add it?
Thanxeversomuch
(2023-09-21, 20:01)Macaroni Slick Wrote: [ -> ]I have a station I'd like to add
Thanxeversomuch
Go to:
My Station => Add custom Station
Enter this ULR:
http://ice42.securenetsystems.net/KAFN
Then you have:
"KAFN Arkansas Rocks FM"
(2023-09-21, 22:03)Fuchs2468 Wrote: [ -> ]Imagehttp://ice42.securenetsystems.net/KAFN
I was asked for a thumbnail or url path.
What would you enter for that?
Also got this error after setting up station and selecting it.
EDIT:- Posting url http://ice42.securenetsystems.net/KAFN in my browser loads a page then I have to select play to play station
(2023-09-22, 07:28)Jeffers24 Wrote: [ -> ]
It's actually self-explanatory.
Go to edit and do 1-3.
1. Enter name: KAFN Arkansas Rocks FM
2. Enter URL or path to the image: https://static.mytuner.mobi/media/tvos_r...mcchkb.jpg
3. Enter URL to the stream: http://ice42.securenetsystems.net/KAFN
Done!
(2023-09-22, 12:27)Fuchs2468 Wrote: [ -> ]http://ice42.securenetsystems.net/KAFN
Thanks, that did the trick  Cool
Thank you! I had the same issue on Windows 11. Living in the Netherlands. Not sure, why this fix the issue...
Hi
I just want to listen some station that are on KODI unplayable but when I try this same station in android app this station are ok. How can I understand it?
I also am finding that there are stations that seem to play fine on the radio.de website but not not in the radio add-on in Kodi, specifically:
https://www.radio.de/s/bbcradio4
This also stopped working in the iPlayer add-on a few days ago, so does it mean that something about the stream has changed, that needs to be updated?
Here is a short guide for users who can listen to their station on the "Radio" website but cannot find this station in the Kodi Radio addon.
As an example I use https://www.radio.de/s/bbcradio4.
- Call up the desired station in the browser
- call view page source text
- Ctrl+F on the keyboard (text search appears)
- enter the following text in the search:
"streams":[{"url":
- the following URL is your stream URL
- You will find a station logo in front of the entry for the stream URL
- a good choice is the logo with c300.png at the end
Result:
Enter the result into the radio add-on “My Stations”.
Done!
Hi, thanks for the addon, works nicely! I noticed m80 portugal themed streams do appear in a search at radio.de (searchterm = 'm80') but they are missing when searching using the addon, why? I thought the api was the same for borth sites....I was just curious about this, anyway I added them manually to my custom stations already. Thanks for the work Smile
I'm using version 3.0.3 on KODI Leia 18.9 in Windows 11 Pro. Things seem to be fine until I request a station previously added to My Stations. I get a "Radio Error Check the log...." The station plays fine as a favorite, or selected from the long lists, but the My Stations piece seems broken. Any ideas?
(2023-11-23, 15:24)hurricane51 Wrote: [ -> ]I'm using version 3.0.3 on KODI Leia 18.9 in Windows 11 Pro. Things seem to be fine until I request a station previously added to My Stations. I get a "Radio Error Check the log...." The station plays fine as a favorite, or selected from the long lists, but the My Stations piece seems broken. Any ideas?
I'm getting the same thing on Kodi 20, previously playing stations giving an error, BBC Radio 1, 2, 3 and 4
