2012-09-25, 10:13
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48
2012-10-05, 10:17
Hello,
Yesterday, I've trying to install de Add-on from the XBMC repository.
Install successfull but, when I've try to launch it, I've a "Python Error : "script python.de" If I remember."
Have you an idea ?
Thanks !
My config : W7 | XBMC Eden
Have you an idea ?
Thanks !
2012-10-06, 12:00
Without an xbmc.log I can't help you, sorry.
2012-10-08, 15:29
Hy!
When i click on the local station, it doesn't work. one window pop up that say: missing addon.py
My log:
what is wrong? Please help me!
My log:
08:53 T:4504 NOTICE: Radio.de scraper: get_most_wanted started with language=english, num_entries=25
15:08:53 T:4504 NOTICE: Radio.de scraper: __get_json started with path=account/getmostwantedbroadcastlists, gets={'sizeoflists': 25}, language=english
15:08:53 T:4504 NOTICE: Radio.de scraper: __urlopen opening url=http://rad.io/info/account/getmostwantedbroadcastlists?sizeoflists=25
15:08:57 T:4504 NOTICE: Radio.de scraper: __urlopen URLError: <urlopen error [Errno 10061] Nem hozható létre kapcsolat, mert a célszámítógép már visszautasította a kapcsolatot>
15:08:57 T:4504 NOTICE: Radio.de scraper: get_most_wanted end
15:08:57 T:4504 ERROR: Error Type: <type 'exceptions.TypeError'>
15:08:57 T:4504 ERROR: Error Contents: 'NoneType' object is unsubscriptable
15:08:57 T:4504 ERROR: Traceback (most recent call last):
File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.audio.radio_de\addon.py", line 313, in <module>
plugin.run()
File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib\xbmcswift\plugin.py", line 330, in run
self.dispatch(self.path)
File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\script.module.xbmcswift\lib\xbmcswift\plugin.py", line 129, in dispatch
return view_func(**items)
File "C:\Users\HTPC\AppData\Roaming\XBMC\addons\plugin.audio.radio_de\addon.py", line 96, in show_local_stations
items = __format_stations(stations['localBroadcasts'])
TypeError: 'NoneType' object is unsubscriptable
15:08:57 T:5180 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.audio.radio_de/local_stations/
15:08:57 T:5180 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.audio.radio_de/local_stations/) failed
15:08:57 T:5752 NOTICE: -->Python Interpreter Initialized<--
15:08:57 T:5752 NOTICE: Radio addon: show_root_menu start
15:08:57 T:5752 NOTICE: Radio addon: show_root_menu end
15:09:01 T:5788 NOTICE: -->Python Interpreter Initialized<--
15:09:01 T:5788 NOTICE: Radio addon: show_local_stations start
15:09:01 T:5788 NOTICE: Radio.de scraper: get_most_wanted started with language=english, num_entries=25
15:09:01 T:5788 NOTICE: Radio.de scraper: __get_json started with path=account/getmostwantedbroadcastlists, gets={'sizeoflists': 25}, language=english
15:09:01 T:5788 NOTICE: Radio.de scraper: __urlopen opening url=http://rad.io/info/account/getmostwantedbroadcastlists?sizeoflists=25
15:09:05 T:5788 NOTICE: Radio.de scraper: __urlopen URLError: <urlopen error [Errno 10061] Nem hozható létre kapcsolat, mert a célszámítógép már visszautasította a kapcsolatot>
15:09:05 T:5788 NOTICE: Radio.de scraper: get_most_wanted end
15:09:05 T:5788 ERROR: Error Type: <type 'exceptions.TypeError'>
15:09:05 T:5788 ERROR: Error Contents: 'NoneType' object is unsubscriptable
15:09:05 T:5788 ERROR: Traceback (most recent call last):
plugin.run()
15:09:05 T:5180 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.audio.radio_de/local_stations/
15:09:05 T:5180 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.audio.radio_de/local_stations/) failed
15:09:05 T:5816 NOTICE: -->Python Interpreter Initialized<--
15:09:05 T:5816 NOTICE: Radio addon: show_root_menu start
15:09:05 T:5816 NOTICE: Radio addon: show_root_menu end
2012-10-08, 15:32
Your XBMC Proxy Settings are wrong.
Please diable Proxy if you don't need (and have) a Proxy server.
2012-10-08, 15:35
It is work!
2012-10-13, 18:54
Is there any way to login into radio.de? I would love to use my favorites in XBMC...
(so I can add a radio station into my favorites on my computer and use it on xbmc next time i am at home
2012-10-14, 12:44
(2012-10-13, 18:54)FreakErn Wrote: [ -> ]Is there any way to login into radio.de? I would love to use my favorites in XBMC...(so I can add a radio station into my favorites on my computer and use it on xbmc next time i am at home
This in on my to-do list. A small problem here is the wording. "Favorites" is XBMC managed but "My Stations" will be the favorites you have in your radio account.
I will announce here when I have the new version ready. This version will also allow to add custom defined station.
2012-10-17, 04:28
nice plugin thx
2012-10-20, 18:33
(2012-10-14, 12:44)sphere Wrote: [ -> ]This in on my to-do list. A small problem here is the wording. "Favorites" is XBMC managed but "My Stations" will be the favorites you have in your radio account.
Can't wait
2012-10-22, 23:03
I have a new version ready for testing - this one will be Version 2.0.0
I rewrote and re-factored most of the code so there could be a few issues - please report any issue here or using github.
One of the biggest change is that you now can add custom stations (user defined stations)! Just go to "My Stations" and choose "Add custom Station" - you need to enter a title, an icon-url (can be local or remote path - or you can leave this empty) and the stream url - this can be a local file (M3U, PLS, STRM) or a remote URL. You can also edit your custom stations later with the context menu Command "Edit Custum Station".
Here is the full Changelog:
You can download this Preview Version here.
Have fun,
sphere
2.0.0 (unreleased)
- Code Rewrite
- Possibility to add custom (user defined) Stations
- Thumbnail View (You can disable in the add-on settings)
- Change to the xbmcswift2 framework
- New Icon
- Possibilty to add Stations to the XBMC Favorites
Have fun,
sphere
2012-10-26, 15:05
Thanks, I've been looking for an addon to replace Shoutcast as they keep changing the stream IDs on me. I tried adding Radio Paradise as a custom station but nothing happens when I tried to play it back.
The URL is http://www.radioparadise.com/musiclinks/rp_128aac.m3u and here's the log:
Any ideas? Thanks!
09:02:59 T:2954915840 NOTICE: -->Python Interpreter Initialized<--
09:02:59 T:2954915840 NOTICE: '{'
09:02:59 T:2954915840 NOTICE: [xbmcswift2] Request for "/station/Radio+Paradise" matches rule for function "get_stream_url"
09:02:59 T:2954915840 NOTICE: [plugin.audio.radio_de] get_stream_url result: http://www.radioparadise.com/musiclinks/rp_128aac.m3u
09:02:59 T:2954915840 ERROR: AddItems - called with an invalid handle.
09:02:59 T:2954915840 ERROR: EndOfDirectory - called with an invalid handle.
09:02:59 T:2897216192 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.audio.radio_de/station/Radio+Paradise]
Any ideas? Thanks!
2012-10-26, 20:44
XBMC doesn't like Playlists files delivered as playable-Items.
Try "http://stream-tx4.radioparadise.com:8012" as stream url (this is one of the streams defined in the M3U Playlist file.
2012-10-27, 18:30
Testing ver 2, things are working well.
Suggestion:
When adding a custom station, is there an "escape" or "exit" for a wrong or blank? Selecting "Done" when blank does not exit the dialoge for me.
Radio station error:
KCRW music - it no longer works as of last week.
Thanks again. This is a must-have plug-in!
Suggestion:
2012-10-27, 20:56
(2012-10-27, 18:30)ixnu Wrote: [ -> ]Testing ver 2, things are working well.Nice
(2012-10-27, 18:30)ixnu Wrote: [ -> ]Suggestion:Im not sure that I get you right. if you leave the title blank the station won't be saved. If you filled the title but not thumb or not url the station will be saved and you need to manually delete it after creating when you want it to be deleted.
(2012-10-27, 18:30)ixnu Wrote: [ -> ]Radio station error:KCRW is broken - but this is not an plugin issue. You can try to report that to KCRW or to radio.de/rad.io/radio.fr support.
Btw. the URL of this station is "http://scfire-ntc-aa04.stream.aol.com/stream/1045" which throws an DNS error.
(2012-10-27, 18:30)ixnu Wrote: [ -> ]Thanks again. This is a must-have plug-in!Your welcome
regards,
sphere
