(2012-10-27, 20:56)sphere Wrote: [ -> ]Im not sure that I get you right. if you leave the title blank the station won't be saved. If you filled the title but not thumb or not url the station will be saved and you need to manually delete it after creating when you want it to be deleted.
Sorry. My mistake. I misread the box. It's working as expected.
One suggestion - it would be nice to have a file picker for custom stations. I have all of my stations (about 15) set up as m3u files. It would be nice on the third screen to have an option to browse the local file system for the m3u or stream files.
Also, when I installed the new version (2.0.0), I lost all previous "My Stations" from ver 1.x.
Again, awesome work!
More info.
I got over 20 custom stations running very well.
Some issues that I have-
I can't seem to get the plug in to find a m3u file. When I enter "c:\xbmc\xxxx.m3u" it does not find it.
When I enter a really long URL, the text does not scroll in the text box.
Thanks for looking into this.
Overall, it is really polished and I've been enjoying it all weekend! With this plugin, I can finally ditch Pandora.
(2012-10-28, 17:30)ixnu Wrote: [ -> ]Also, when I installed the new version (2.0.0), I lost all previous "My Stations" from ver 1.x.
i have added an automatic migration for the my-stations from version 1.x to 2.x.
Download Version 2.0.1
If there are no bugreports I will push this version to the repo.
regards,
sphere
Hello.
"My Stations" stopped working.
I deleted the file ~/.xbmc/userdata/addon_data/plugin.audio.radio_de/storage/my_stations.json and now it works again.
This is the xbmc.log file:
http://pastebin.com/embed_js.php?i=A9Jq49MN
Is there another way to solve this problem?
Thanks,
Patrizia.
(2012-11-02, 14:40)Patrizia Wrote: [ -> ]I deleted the file ~/.xbmc/userdata/addon_data/plugin.audio.radio_de/storage/my_stations.json and now it works again.
Hi Patrizia,
do you still have the my_stations.json? If yes, can you send it to me? (link, via PM if you prefer)
Did you add a custom station?
regards,
sphere
I fixed the issue (unfortunately this works only for new added custom stations - so if you already have a wrong custom station the file needs to be deleted).
I uploaded a fixed Version 2.0.1 (you need to re-download and re-install via .zip)
Version 2.0.1 is in the Repository now.
Have fun!
sphere
(2012-12-16, 04:36)dieselboy27 Wrote: [ -> ]Can someone help me to find the link I would add to stream this station?
http://www.chinradio.com/radio-programs/ukranian/
I'm not sure how to go about finding the link so that I can add it to my custom stations.
Should be: "http://ice7.securenetsystems.net/CHINFM?type=.flv" as stream-url.
(2012-12-15, 15:06)schumi2004 Wrote: [ -> ]Today i wanted to try this addon (Latest XBMC RC1) but it only gives me errors
Any ideas?
http://xbmclogs.com/show.php?id=21340
I'm already working on it, an update including this fix will be opened as pull request to the official add-on repository today.
regards,
sphere
sphere awesome, thanks
Edit:
Not yet updated on Github right ?
//Your fast
Stations for the Netherlands only goes to L (100 items)
Nothing after that. You want a
Debug Log?
(2012-12-17, 22:40)Martijn Wrote: [ -> ]Stations for the Netherlands only goes to L (100 items)
Nothing after that. You want a debug log?
No debug log needed.
They have done API changes (pagination in category filtering) without noticing me
Thanks for the report, I will implement the needed changes...
regards,
sphere
Np
Just tried before my sister began to complain
