2012-01-10, 10:06
ok so i got untethered jb with seasonpass on 4.4.4
then i got xbmc - brilliant!
then i got nito tv - brilliant
i would like couchsurfer and i would like my iphone 4 (not 4s) to stream airplay content - i installed the fix on my iphone but it still wont play vids - just freezes
also - is it possible to install plex and sapphire as well
and rowmote works ok (buggy) but remote hd will not connect at all!?
ok guys thanks in advance
by the way i use windows 7 and putty wont let me connect to give terminal instructions so i use terminal on my iphone - winscp is ok for ssh into files though
