Full Version: Confluence Movie Info
Just noticed that when viewing a folder from the files section and setting the view to Media List 2 the Plot/Outline is not displayed for Movies. When doing the same for TV shows the info is diaplayed.
Is this something that will be fixed or just live with it.
thanks
Seems to be a problem on your end...
This is working fine on my end...
You are running Eden Beta1?
cheers,
mad-max
Just guessing as I've not checked but if browsing files then you're not in the library mode and therefore no plot etc. Where as TVShows will be in library mode. If you go to Media List 2 through the movies not files option does everything work?
i guess this has been fixed in beta 1 (if it is this what you are talking about)
http://forum.xbmc.org/showthread.php?tid=117061
https://github.com/xbmc/xbmc/commit/405e...5cef9b7f78
