(2012-08-08, 23:30)Hitcher Wrote: [ -> ]@Martijn, I've noticed there's a problem with titles containing the '&' character. Everything before '&' gets cut off and this in turn messes up adding to CP.
ie 'Robot & Frank' gets listed as 'Robot' and CP looks for 'Robot (2012)' and fails.
I'm sorry but this is wrong
. The Movie title is indeed listed as just "Robot" (Although the cover says "Robot & Frank").
Have a look into the itunes XML:
http://trailers.apple.com/trailers/home/xml/current.xml (search for "5060").
regards,
sphere
Sometimes there are more flaws in their XML file like listing the same trailer twice
I'm also getting no covers recently...
(2012-08-10, 16:22)markswift Wrote: [ -> ]I'm also getting no covers recently...
I can't reproduce it. If still have this problem please provide us with more informations.
(2012-08-10, 22:34)sphere Wrote: [ -> ] (2012-08-10, 16:22)markswift Wrote: [ -> ]I'm also getting no covers recently...
Works without issues for me to
Yes, it seems to be something to do with the ReFocus Big theme and Nox works fine!
(2012-08-11, 11:08)markswift Wrote: [ -> ]Yes, it seems to be something to do with the ReFocus Big theme and Nox works fine!
Thanks for reporting. It was indeed a skin issue and it has been already fixed.
The Trailers add-on is working as expected.
I can't download or stream a lot of the releases from last week.
Debug log.
(2012-08-13, 17:22)Hitcher Wrote: [ -> ]I can't download or stream a lot of the releases from last week.
Debug log.
I can confirm that issue. But unfortunately I can't quick fix it
The movie's trailer kinds (Trailer 1, Trailer 2, Teaser 1, ...) are missing in the movie detail xml file. I need to find the (new?) way how itunes is getting this data and then I will fix the plugin.
Thanks for reporting!
Was just wondering if we could see support for couchpotatoV2 added?
Thanks for the work!
would also love to see support for couchpotato v2, thanks
(2012-06-21, 00:42)Martijn Wrote: [ -> ]Note:
Nothing has been changed about the CouchPotato code. I haven't got a CP server so can't test it.
(2012-04-03, 07:19)Martijn Wrote: [ -> ]I don't use Couchpotato so it's way down my to-do list.
Don´t know if it is helpful at all or even wanted, but I imagine it´s harder to code for something you don´t personally use.
So here is a
debug log of me trying to add a movie to latest
CouchPotatoServer
within stable
XBMC Eden v11.0 on a Windows machine.
If you ever have the urge and time to try to support CP v2, you have at least something to go on.
Great plugin Martijn! Absolutely loving it and spending too much time watching trailers
A Quick question: Is there a way to select multiple items, and then use the context menu to run the 'download' function on all of them? I'm having mixed results with streaming, so right now i'm just going over all the trailers i want to download and run it one by one.
Again, great addon! thanks!
Oh! And I don't know if I missed anything, but I didn't find a way to just watch all the trailers in a randomized fashion. If Anyone's been looking for a way to do that, the solution I worked up was to use PseudoTV and set a custom channel to 'The Trailers' directory.
